Z Tube install?
Old Sep 23, 2008 | 05:17 AM
hawaii's Avatar
Z Tube install?
Is there a DIY: Z Tube install by any chance? I might get one and just want to see the level of difficulty. Thanks in advance guys
Old Sep 23, 2008 | 08:45 AM
elrooko's Avatar
Dude - please search...there are a bagillion of these on here...15 seconds I found this one, there are a ton more
https://g35driver.com/forums/intake-...e-install.html or this one
DIY: Z-Tube in install
Old Sep 23, 2008 | 08:47 AM
Boston's Avatar
So simple, Ray Charles could install it.
Old Sep 23, 2008 | 09:24 AM
RBull's Avatar
Rated M
Yeah, a DIY isn't really needed. The toughest thing was the airbox.
Old Sep 23, 2008 | 09:51 AM
Project's Avatar
idk can you twist a screw driver or ratchet a bolt?
Old Sep 23, 2008 | 06:06 PM
hawaii's Avatar
Ok thanks but i just wanted to be sure.. I just bought a g and unfortunately im not an amateur like some of you guys.
Old Sep 23, 2008 | 10:07 PM
Project's Avatar
you mean pro its okay we understand
Old Oct 2, 2008 | 02:10 PM
Maxypad's Avatar
Whats do u have to do different when installing the popcharger with the ztube which im about to do next week
Old Jun 14, 2010 | 10:41 PM
Dani01c's Avatar
is it really necessary to remove the negative pole to "resent" the ECU?
Old Jun 14, 2010 | 10:43 PM
ilovez33's Avatar
There are other ways to reset but they havn't been legitmatly tested. Removing the negative terminal for a few hours is the shure fire way to make it happen.
Old Jun 14, 2010 | 10:44 PM
ilovez33's Avatar
I installed my Z-Tube with heat shield and pop charger in under 30 minutes and that was with a beer break.
Old Jun 14, 2010 | 11:10 PM
Dani01c's Avatar
i just finished installing it right now! i guess ill take of the negative pole out right now and put it back on tomorrow when i wake up! thanks!
Old Jun 17, 2010 | 09:52 PM
rickyrch's Avatar
quick question.. i just received the stillen z pipe.... did you guys use the stock couplers?
Old Jun 17, 2010 | 10:04 PM
rickyrch's Avatar
i ment to say z tube
Old Jun 17, 2010 | 11:02 PM
youngG's Avatar
yes u have to use couplers
