Question for those with HKS (rear section)
Old Sep 28, 2008 | 06:36 PM
ohmrwilson13's Avatar
Q: At what rpm do you start to "hear" your exhaust?
I'm contemplating purchasing this muffler, and have read here that under normal conditions, it's nearly silent. I also understand that under WOT and 5-6K rpm it becomes a beast ;]
I was curious as to what RPM range gave you a: 1. murmur, 2. burble, and 3 roar.
I would prefer the idle to be nearly silent, and as little drone as possible, which is why I'm looking at the HKS, but still want to go "vroom-vroom" when I get it above 4K.
Thanks in advance!!!
Old Sep 28, 2008 | 07:19 PM
absolutg's Avatar
workin...
you can definitely hear it at lower RPM, i notice it at 2k but it picks up quite a bit over 4k
Old Sep 28, 2008 | 08:44 PM
sloppymax's Avatar
when i had mine on, it was noticeable at any rpm including idle. that was before the y pipe and hfcs at which point it became too loud. i thought it sounded great at wot but the low rpms with an auto was a tad annoying in my opinion..
Old Sep 29, 2008 | 02:11 AM
Thanks for the input, guys! The information is incredibly helpful.
So I guess the million dollar question is:
Does it drone at 2.5K RPM on the freeway, 70-75mph cruise?
You mention you could hear it at 2K rpm....which would leave me to believe that it would drone at 2.5K =/ ?
Many Thanks.
Old Sep 29, 2008 | 02:14 AM
Which Y pipes are you running? And did the y pipe or hfc's make more noise?
Also, if you don't mind me asking, what setup are you running now?
Sorry for being so inquisitive; I merely don't want to make a purchase only to suffer buyer's remorse =)
thankyouthankyouthankyou.
Old Sep 29, 2008 | 06:59 AM
sloppymax's Avatar
I have a Tanabe y pipe since it has smaller inlet dimensions the 3" inlet y pipes. The hfcs are berk. I had the y pipe on with the hks and it sounded good. A little annoying around 70mph cruising and going up hills at a low rpm. After the hfcs, it got too loud. I would have to say the hfcs would cause a higher effect on the tone and volume of the exhaust than the y pipe.
Right now its just the hfcs and y pipe on with everything else stock. I still have the hks sitting in the garage. I could stand a little more sound soI have considered using a round magnaflow resonator to replace the one in the stock midpipe one as a few members have done but no definite plans of yet. I will mention that I am probably more sensitive to the noise than others. In my previous VQ30, the entire exhaust was aftermarket except the rear section, which worked great for me.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
