please help
Old May 18, 2004 | 02:35 AM
Jatt_G35's Avatar
please help
I was installing my new JWT Popcharger and Ztube and followed Speedoholics excellent walkthrough but had a problem.
the rubber padding on the heatsheild seems to have curled up inside leaving a gap between the heatsheild and the air scoop where the air can escape
is this normal? or does anyone know how to fix it so that the heatsheild and the air scoop have a perfect seal
thanks
Old May 18, 2004 | 09:00 AM
TooFastSGG35's Avatar
Re: please help
You aren't going to have a perfect seal with this. Just make sure that you have the padding on so that it will fold over in the right direction. And also make sure that you have thouroughly pushed it so that it is all the way on because it's easy to think that it is all the way on and it isn't. And one thing that I did make sure of was because each pad has a gap when installed I orientated them so that the gaps wont meet in the same place so the gaps are covered by each pad. But make sure that you really take your time to work those things on.
