G35 NA stroker with ITBs
Old Nov 10, 2008 | 07:20 AM
  #76
WhosUrBuddiee's Avatar
Are you building a carbon fiber cover for them? Should look beautiful.
Old Nov 10, 2008 | 09:44 AM
  #77
fluffy's Avatar
what a beast!
Old Nov 10, 2008 | 04:03 PM
  #78
IvoryGT's Avatar
Yes, eventually a specialized box would be made to shield it from the elements. CF would just be the finishing touch.
Old Nov 10, 2008 | 08:47 PM
  #79
Hal@IP's Avatar
Here is a pic of Ivory's car at SEMA 2008. Car looks hot Paul, great job pulling everything off in time for the show!
Old Nov 10, 2008 | 08:55 PM
  #80
accordfreak's Avatar
he repainted his car?? ??
Old Nov 10, 2008 | 08:57 PM
  #81
Hal@IP's Avatar
That is correct
Old Nov 10, 2008 | 10:01 PM
  #82
infinus's Avatar
That's bad ***, cant wait to get home from work so I can see the vids
Old Nov 11, 2008 | 02:08 AM
  #83
SixOneFive's Avatar
Man, what a beast!
Old Nov 11, 2008 | 01:17 PM
  #84
xx7sephiroth7xx's Avatar
G
wow, looks incredible. i thought ivorygt had a sedan?
still pretty sickkkkk.
Old Nov 11, 2008 | 01:22 PM
  #85
mIKE's Avatar
Having seen the car in person, MASSIVE props
I probably spent half an hour at the booth.
Old Nov 11, 2008 | 02:42 PM
  #86
DaveB's Avatar
Originally Posted by IvoryGT
The ITBs aren't that expensive compared to the Stroker build.
I went with ITB because I was doing NA build already. What's so good about NA? I don't need to wait for boost, don't need to have 100 different gauges, don't need to worry about vacuum hoses or 100 other different things that could go wrong with FI.
Most of all, the immediate power is uncompromising. The curve is like stock, so imagine same kind of driving characteristics just with 85 more hp to the wheels.
But haven't you lost cruise control, ABS, and stability control going with this setup and are also using a standalone? If so, that sounds like a lot of compromise to me.
We have a shop here in Kansas City that just added a twin turbo kit to a G8 GT. The turbos are variable vane units, electronically controlled, and sealed. That means no oil lines, no waste gates, and full power straight from 2000rpms. This will be the future of turbo technology and will make installs a breeze.
That's awesome you've done something different, but I'd much rather have the power band of a well-tuned turbo car vs an NA car. An 85hp gain on a turbo car will equal a FAR fatter powerband than an NA car with an 85hp gain.
Old Nov 11, 2008 | 07:14 PM
  #87
GEE PASTA's Avatar
Florida G35 Club
Nice build.
I would advance the cams a bit.
The cam buckets are way to loose for that kind of RPM'S.
Great project/great results.
Old Nov 11, 2008 | 07:29 PM
  #88
fluffy's Avatar
what a unique colored beast
Old Nov 12, 2008 | 11:56 AM
  #89
IvoryGT's Avatar
Still have my ABS and stability...I don't know why you think that'd be lost?
Also having NA means I dont have to wait for the turbo to spool. Frankly I know my motor will continue to work for 10 years with regular fluid change. Can same be said about a turbo setup that is daily driven?
Old Nov 12, 2008 | 11:57 AM
  #90
IvoryGT's Avatar
Nice Pic hal...definitely captured the color well.
Thanks for the props guys...It damn nearly killed me getting the car to the show in time.
