Kinetix Upper plenum ???'s
Old Oct 4, 2008 | 06:28 PM
mikeman2459's Avatar
will the kinetix upper plenum fit with my MD 5/16 spacer, and MREV2 because it looks like it doesnt have the 6 center bolts in the middle of the plenum. and is it a mod worth getting? I already have test pipes, cat-back, pop charger, z-tube, mrev2, and 5/16 spacer. so pretty much im going for this or if theres somewhere else i should spend my money let me know.
Old Oct 4, 2008 | 06:42 PM
Chamoru671's Avatar
way do you need a kinetix upper plenum when you already have MD spacer, and mrev2. the thing you have to worry about is the clearance of your hood when you close it. you will be fine w/you stock plenum, MD spacer and mrev2 and the other mods you have.
Old Oct 5, 2008 | 01:27 AM
Chef-j's Avatar
The Kinetix and spacer are not compatible with eahother. When a spacer is added, it lifts the support column off its resting point and the upper panel of the Kinetix is left unsupported.
I will sell ur kinetix and save money and get a tune
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
