low engine idle
Old Nov 19, 2008 | 01:30 AM
Hydrazine's Avatar
Stalling at freeway speeds is very common for intakes.
As an experiment, put your stock box back on for a few days and see if the problem goes away. It most likely will.
At least you can trouble shoot the source.
Old Nov 19, 2008 | 10:49 AM
805g's Avatar
i'm not stalling at freeway speeds. I'm stalling when i decellerate FROM freeway speed like exiting the freeway and braking hard with out downshifting through the gears to keep the rpms up. The rpms tend to drop fast and stall out if i do not engine brake.
Old Nov 19, 2008 | 12:23 PM
Hydrazine's Avatar
Yes. That's how it happens.
Try the stock box for a few days. It will most likely eliminate the problem.
Old Nov 19, 2008 | 12:45 PM
805g's Avatar
i will have to look for that thing! hahaha
Old Nov 19, 2008 | 08:44 PM
805g's Avatar
so i've got an injen cold air intake and i think i need a new filter...
I recently used a K&N recharge kit on it. Was that even ok to do?
Also where can i get a replacement filter?
again, thank you all
Old Nov 20, 2008 | 02:58 AM
chenG35's Avatar
^make sure you don't over oil your filter - I did that once lol and learned the hard way when the engine stalled when it's warming up.
Old Nov 20, 2008 | 08:45 AM
Hydrazine's Avatar
The oil is another common problem with CAI's. The oil comes off the filter as fine droplets when at high load where if flows down the intake tube and to the MAF sensor. The oil gets all over the MAF sensor and it can't function properly.
You may need to clean your MAF sensor.
Old Nov 20, 2008 | 10:58 AM
805g's Avatar
i just cleaned the maf sensor. still same prob. When i removed the sensor it was not oily at all. I sprayed it with some maf cleaner then replaced...
Old Nov 20, 2008 | 12:02 PM
Hydrazine's Avatar
That's good. Now try the stock box.
Old Nov 26, 2008 | 01:44 PM
coolbratva's Avatar
I have stillen intake and I have the same crap happening to me but I had the intake for a year now and it started about three months ago. Replaced the maf sensor same sh!?t. It is really getting on my nerves, but i don't have the stock airbox. So if you guys figure it out, let me know>
Old Nov 27, 2008 | 12:24 PM
805g's Avatar
yea cool, i don't believe i have the stock airbox.
I might try cleaning my Throttle Body soon. I cleaned the MAF sensor and nothing changed.
Old Nov 27, 2008 | 02:09 PM
Hydrazine's Avatar
BE VERY CAREFUL CLEANING YOUR THROTTLE BODY!
CEL's happen.
Old Dec 30, 2008 | 01:51 AM
Knowledge35's Avatar
My car is recently getting low engine idle
I just did the oil change and a week before cleaned out the intake...
Old Dec 30, 2008 | 11:12 PM
heres a pic of my RPM Gage is it normal?
<a href="http://s22.photobucket.com/albums/b337/Knowledge7478/?action=view&current=grpms.jpg" target="_blank"><img src="http://i22.photobucket.com/albums/b337/Knowledge7478/grpms.jpg" border="0" alt="Photobucket"></a>
Old Dec 30, 2008 | 11:23 PM
  #30
OCG35's Avatar
^^^ 600rpm = slightly low, but I wouldnt be too concerned.
