Z-Tube or Not to Z-Tube - Opinions Wanted...
Old May 25, 2004 | 02:55 PM
TXCanuck's Avatar
I am considering swapping stock to Z-tube, I am going to keep the stock airbox due to many posts I've read here and over at freshalloy. I do not want an oil-based filter due to potential MAF issues (I had a MAF issue with a K&N on my old explorer).
I would like to hear your comments pro or con z-tube. Is it worth it or shall I just stick to stock? Is the sound difference noticeable and if so is it worth it just for that?
Old May 25, 2004 | 02:59 PM
SFLG35's Avatar
FGC President
Re: Z-Tube or Not to Z-Tube - Opinions Wanted...
to ztube is the answer. def noticable sounds difference. i have that exact setup ztube and stock airbox. check out the dyno results thread. and you will see all our results as well as mine.
Daniel
5ATC / DP / Willow / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up / VDC Memory
Old May 25, 2004 | 03:06 PM
TXCanuck's Avatar
I read that post this morning. Your result is what is pushing me towards doing it. Thanks for the reply.
Old May 25, 2004 | 03:07 PM
neffster's Avatar
Z-tube is ounce for ounce and dollar for dollar the best mod you can do for your car. Although you will probably not notice the performance gain in the seat of your pants, it is there. Plus the sounds it generates are awesome when you rev past 4k rpm.
301-bhp!!! ...and growing!
Old May 25, 2004 | 04:16 PM
stormxshadow's Avatar
i agree with the rest... i had the jwt popcharger before the z-tube and the sound was good but once i put on the z-tube its like i had awoken a beast...go for it!
FIUTOBOT's G
Old May 25, 2004 | 04:31 PM
G35Papa's Avatar
Dito.......what he said.
I have the same setup as SFLG35. Growl is awesome! Zoom zoom zoom, right past the Mazdas!!
G35papa
2003 Pearl White - Premium Willow - Clear Corners (moded) - Z-tube - 18" OEMs- Tinted all around
Old May 25, 2004 | 06:13 PM
Gyromight's Avatar
just make sure you insulate your A/C line before installing or you'll regret the intake install. There's a big a$$ thread about it at the beginning of this forum.
2004 G35C H.O. Tint, Z-tube/JWT Popcharger, Clears
Old May 25, 2004 | 10:50 PM
SixFive's Avatar
? If anything the Z tube will give the AC line more room.
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk ex-3500 Tweeter Upgrade/Shock Sensor/H-Liner Under Hood
Old May 26, 2004 | 02:16 AM
DHCrocks's Avatar
if you use the stock air box then you don't have to worry about the ac line clearance, there is a lot of room. it's only the aftermarket filters that seem to cause a problem.
Old May 26, 2004 | 02:50 AM
skaline's Avatar
I also have to vote yes on the Z-tube. No AC line problems and the growl is great. Also, try removing the resonator under the stock airbox.
Old May 26, 2004 | 08:07 AM
NYCXLR8's Avatar
Thumbs up on the Z-Tube. I also wanted to avoid the CAI's that are out there. I did the Z-tube and added a K&N drop in filter in the stock air box. The sound alone is worth doing the mod. I'm sure there is a little power there too.
Definately do it.
2004 G35c 5AT/Prem Pkg/18" Tire Opt/Aero Kit/Clear Sides/Pedal Kit/Tint/Z-Tube/K&N Drop-in
Old May 26, 2004 | 11:14 AM
av8r's Avatar
You won't notice any performance gains (other than phychological). Lets face it, 1 or 2 hp is not going to make a difference. Sounds awsome though!!!
2004 Sedan 6MT
Silver/Graphite/Premium/Aero
HuperOptik Ceramic 50/Clear Corners/XM Radio
Z-Tube/Stillen High Flow Airbox/Grounding Kit
Old May 26, 2004 | 11:44 AM
Gyromight's Avatar
Not according to this thread:
https://g35driver.com/forums/showfla...&part=all&vc=1
its anybody who has a Z-tube however it tends to affect PC-tube users more.
Old May 26, 2004 | 12:28 PM
madabs's Avatar
stay with the stock tube and plugged up the hole with some plastic pieces and epoxy. i used a tire patch kit that had pre cut cirlces that fit perfectly.cost 1.99 for pathes 5 for epoxy
<P ID="edit"><FONT class="small"><EM>Edited by madabs on 05/26/04 09:29 AM.</EM></FONT></P>
Old May 26, 2004 | 12:31 PM
TXCanuck's Avatar
Thanks for the overwhelming response.
I ordered it yesterday from everythingG35.com.
