Pay $$ for Labor or DIY??
Old Feb 1, 2009 | 09:35 PM
Wiseman's Avatar
Next weekend I'll have the HKS muffler and an 06 midpipe to install. I've read a few threads on here, seems like the easiest option is to pay $50-100 for a shop to install and be done with it. On the other hand I'd really like to have the satisfaction of doing these mods myself and a few buds; I guess I'm looking at a few hours to do this and both if these items are bolt on, correct? What would be the most challenging part of this, what irregular tools if any would I need? Thanks for the input.
Old Feb 1, 2009 | 09:38 PM
SDGeneralCounsel's Avatar
depends on what your budget is and if you like working on cars. Installing a new muffler and midpipe on a sedan isn't very complicated.
simpson's Avatar
wd 40 for taking the hangers out of the boots. jack it up put it on jack stands and less then a hour your good to go
Old Feb 1, 2009 | 10:32 PM
twin001's Avatar
a few hours should do it...most of which will be you waiting for the WD40/PB Blaster to penetrate the bolts.
Old Feb 1, 2009 | 10:39 PM
simpson's Avatar
yeah start spraying them now..... by the weekend they should be great
Old Feb 2, 2009 | 06:57 AM
Wiseman's Avatar
Sounds good, thanks for the replies. Gotta go pick up that PB Blaster now.
Old Feb 2, 2009 | 09:50 AM
canucklehead's Avatar
do it yourself, it's a very simple exhaust swap. grab some jack stands, sockets, and rust-buster and you're good-to-go. i did my swap in ~1.5 hrs, taking my time. the toughest part was releasing the hanger brackets. lube them up well and pull hard!
Old Feb 2, 2009 | 12:30 PM
G SEDAN's Avatar
my advice to you is.......
make sure the car is secure on jackstands before you get under.......get a breakerbar is you can because those bolts will be a b!tch to get out even if you sprayed WD40 on it. And piece the exhaust completeyl together before putting on the hangers and bolting it up. Having a buddy lift it while you're aligning it is great help.
DO NOT try to bolt the mid pipe up to the Y pipe first and then putting the muffler onto the mid pipe, you need to do it all at once or else you will have a hard time aligning all the bolts and hangers while you're on the floor.
Old Feb 2, 2009 | 06:54 PM
Stinger's Avatar
I guess one important aspect of DIY is buying some beer for your buds if they help you out. Especially if they "helped" you in some other installs. And if he has ramps and a metric set i mean isnt that a great guy. He deserves beer and womens.
Old Feb 2, 2009 | 07:10 PM
Wiseman's Avatar
Yuenglings all around! You're on your own with women.
Old Feb 2, 2009 | 07:33 PM
Philly_G35's Avatar
Definitely DIY. Also make sure to use 6 point sockets not 12. Much less of a chance to round off a bolt head with a 6 point.
Old Feb 3, 2009 | 02:27 PM
Stinger's Avatar
Ah noice, i was going to try that ying ling stuff at some point. now then, we dont have a breaker bar. my uncle doesnt have one either, brusche and i needed one that time dougs maxima got wrecked. maybe you could consider giving him a hand scooter since u r having him do all this work for you for free, and if he doesnt have a breaker bar trust me he is going to be working.
Old Feb 3, 2009 | 02:35 PM
shabarivas's Avatar
make a breaker bar... shove an iron broom handle into the long end of your wrench :0
Old Feb 4, 2009 | 12:24 PM
ttrank's Avatar
Grocery getter
DIY all the way if you have a garage or the wather is good. It takes a few hours and PB for the old bolts is a must.
Old Feb 4, 2009 | 12:30 PM
ShanesG's Avatar
Hey, what is your car on in your avatar??? is it like a mini lift?
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
