My Dyno day with Motordyne Bolt-ons..
Old Apr 27, 2009 | 09:59 PM
Hydrazine's Avatar
On the revup or non revup, the 5/16" spacer makes a higher average power and the 1/2" spacer makes a higher peak power. Which is best depends on what trade works best for your application.
In any case, the exhaust addition makes the redline power higher (as shown in the plots above).
Old Apr 28, 2009 | 08:23 AM
Reality350's Avatar
Originally Posted by gabe3d
Great gains! I wish I had a revup engine to get these gains. Did you get a tune or rectify the AFR after the install? When I did my before/after, my AFR were all over the place.
BTW, what model of the Z is the 2006 GT PPW?
No tune yet. I am considering adding some equal length headers when I purchase my HFC's, then get the Osiris reflash.
The z model is a 2006 Grand Touring, Pikes Peak White, 6mt.
Old Apr 28, 2009 | 08:24 AM
Reality350's Avatar
Tony,
I am loving the y-pipe bro!
Old Apr 28, 2009 | 10:59 AM
G35fromPA's Avatar
That is to be expected. The XYZ pipe has larger diameter primaries than the stock Y pipe. Its a trade, but overall its a trade well worth doing.
In development, I also tested a 2.25" version of the XYZ pipe. It had a little more TQ in the 1500-3000 RPM range but then it lost about 2-3 HP over the rest of the curve above ~3500 RPM. 2.25" wasn't a good trade.
2.5" primaries provided the best overall results.
Interesting. Is that because it's a single into dual as opposed to a true dual? i.e. if it were a true dual, do you think 2.25" would be better?
Old Apr 28, 2009 | 11:52 AM
Hydrazine's Avatar
No. Single or dual doesn't make a difference if they are merged correctly. The number of flow paths after the merge point doesn't make a difference if its 1, 2, 3 flow paths or even if its fully open.
The first 2 feet of the primaries is the reactive part of the exhaust system. It is what determines the power curve slope angle.
Beyond 2 feet, the only thing that matters is the flow resistance. IE how free flowing it is. And flow resistance should be minimized to any practical extent possible.
Old Apr 28, 2009 | 02:23 PM
DaveB's Avatar
So how much are these Y-pipes
Old Apr 28, 2009 | 04:42 PM
Hydrazine's Avatar
It depends on what version. There are three listed on the website and it starts at $460.
Old Jun 14, 2009 | 03:30 AM
SLEeper G's Avatar
Which type gives more overall power and torque? Will this work well with an HKS dual Hi power exhaust?
Old Jun 14, 2009 | 08:39 AM
Hydrazine's Avatar
The resonated XYZ.
No. They can't be used together.
Old Jun 14, 2009 | 09:42 AM
O HELLA OEM's Avatar
i just got a used motordyne 5/16 iso copper spacer from a forum member
i felt better throttle response
it just felt alot quicker! i love this mod
Old Jun 14, 2009 | 08:43 PM
SLEeper G's Avatar
The resonated XYZ.
Can you explain the reason why the XYZ pipe can't work with the HKS exhaust? Thanks Tony
Old Jun 14, 2009 | 11:17 PM
Hydrazine's Avatar
The XYZ and the HKS both connect to the exact same place (on the catalytic converters) . You can only have one or the other.
Old Jun 16, 2009 | 01:34 AM
SLEeper G's Avatar
Sorry Tony...what i meant was if i take out the Y pipe off the HKS exhaust system, will the XYZ Y pipe work with the remainding HKS exhaust ie...the mid pipe to the exhaust ports.
Old Jun 16, 2009 | 07:51 AM
Hydrazine's Avatar
OK, in that case yes.
I was thinking of the HKS dual system.
Old Jun 16, 2009 | 07:57 AM
  #30
xXHotelCrazyXx's Avatar
Very nice!
