Re: Compatibility question, z-tube & AEM dry flow filter
Old Apr 29, 2009 | 03:07 PM
HBK2639's Avatar
What's up Everyone, I have a question and maybe someone in here will have an answer. Has anyone try pairing up a z-tube with the aem dry flow air filter?
If yes then does it fit perfectly? From the look of it the aem dry flow air filter is easier to clean and less messy as compare to the oil base filter such as the jwt pop charger.
By any chance is there anyone in this forum that is selling their oem z-tube?
Old Apr 29, 2009 | 03:31 PM
a1exder's Avatar
You can buy a z-tube on g35parts.com or if ur short on cash check the marketplace. AEM filters have a certain size you can find this with a little searching and other filters that are similar to AEM with different sizes work.
Old Apr 29, 2009 | 04:02 PM
gary c's Avatar
Compatible yes....available SEARCH!
Our Z-Tubes are available almost everywhere, I believe Stillen even makes one that looks like carbon fiber (CF) if that's what you like. Intake filters, this has been discussed numerous times on Driver....SEARCH under intake filters.
Gary
Old Apr 29, 2009 | 07:12 PM
Dsskyline's Avatar
go on ebay buy a maf adapter and buy the aem filter with the 3in dia opening then your all set. Also you will need 4 screws and nuts to connect the filter to your maf.
I have pictures of it in my drag thread.
https://g35driver.com/forums/drag/25...13-49-5at.html
Pcruz
Aug 12, 2015 07:46 PM
Team STILLEN
Aug 10, 2015 08:17 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
ClwMike
Jul 23, 2015 12:55 PM
