headers dont fit auto?
Old May 24, 2009 | 10:58 PM
yourfuneral's Avatar
i spend all day ripping apart my 04 G35 AT to throw some headers on it and then when i go to install them, there's not enough clearance in between the firewall and the trans........
am i missing something or am i hosed?
Old May 25, 2009 | 01:33 AM
mysterymann's Avatar
Is it G35 or G37
lol G36 is new to me
What brand are they and where did you get them
Old May 25, 2009 | 03:13 AM
Originally Posted by mysterymann
Is it G35 or G37
some off brand from ebay.
i saw a tutorial about someone else who had purchased and successfully installed headers like these and figured why not?
is there more clearance with the 6mt? sedan? i dunno.....ill sure be pissed to find out i spent 5 horus tearing apart my car for nothing.
Old May 25, 2009 | 09:48 AM
GT-ER's Avatar
I installed mine on my 5at sedan and it fit fine. You just have to play with it. On the drivers side I loosened the steering shaft and on the passenger side I loosened the fuel lines so that they had enough play to move them out of the way a make a little more space.
Old May 25, 2009 | 11:52 AM
They should fit
Do what he said ^^^
Old May 25, 2009 | 12:25 PM
DaveB's Avatar
Well there's you problem. Aftermarket headers are made by hand in jigs which isn't a good thing when you consider just how tight the clearances are under the hood of these cars. There are no additional clearance issues with the 5AT vs 6MT. The problem is with the build quality of your headers. Lots of poor quality aftermarket headers have clearance issues with the steering shafts, manifold studs (ie can't get the nuts on), fuel lines (scary), cat alignment, and frame rails.
Old May 25, 2009 | 02:23 PM
this is a big time clearance issue.....like it must be off by at least an inch.
i've loosened the steering shaft.
ive removed some sheet metal so the steering shaft can move more, ive pounded some metal outta the way to no avail.......
ive tried every way possible just to get the header in there somehow....and this is on the drivers side! the easy side!
Old May 25, 2009 | 04:32 PM
GT-ER's Avatar
Mine are ebay headers and they worked fine, which ones did you get?
Old May 25, 2009 | 09:31 PM
rip off jdm ones.
got everything back together except for one of the bolts on the driverside manifold.... it wont go on for some reason, it doesnt sound like its leaking though..... oh well.
time to find some new ones.
what ebay headers do you have and how do you like them?
Old May 25, 2009 | 11:36 PM
GT-ER's Avatar
rip off jdm ones.
I have some that are called Edge Racing. They fit great and are a copy of DC Sport headers.
Old May 26, 2009 | 02:40 AM
Tollboothwilley's Avatar
The headers are a tough fit. There just isn't a lot of room in the engine bay to work with. I took out all of the studs to slide the header in place, then reinstalled the studs and then the nuts.
Lot of work though.
Old May 26, 2009 | 05:20 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry to hear about your problem, but lesson learned. You usually get what you pay for. Don't buy cheap sh*t. I'm still learning this one. haha
Old May 26, 2009 | 08:21 AM
GT-ER's Avatar
Lot of work though.
Wow...I didn't have to remove any studs. They were a tight fit but not THAT tight.
Old May 27, 2009 | 05:34 PM
removing the studs wouldnt have done it for me.
these were waaaay too big.
the ports were all in the right spots when i matched them up to the stockers...
from what ive read headers dont do much anyways....
i guess the next time i do them it will be eaiser.
next time ill go with a more reputable brand.
i searched for the edge headers on ebay but couldnt find them....oh well.
Old May 27, 2009 | 05:53 PM
Hrmm...thats weird. What brand did you buy? Post a link.
