quick question on the Z-tube...
Old May 26, 2009 | 11:39 PM
O4G_ride's Avatar
Cool quick question on the Z-tube...
I just got a z-tube for my 04 sedan... BUT it came of a twin turbo Z... it has oil inside the tube itself. I hear that's normal if you have a twin turbo... Mine is bone stock. What can I clean it with? Intake Cleaner, engine degreaser? How clean must it be?
Old May 26, 2009 | 11:43 PM
eljoker's Avatar
was this twin turbo Z stock? and oil in an intake is a no no
Old May 26, 2009 | 11:56 PM
O4G_ride's Avatar
Question say what?
A stock 350z does not come with twin turbos. This car was made into a twin turbo yet it had it's stock intake tube. Make sense?
Old May 26, 2009 | 11:59 PM
eljoker's Avatar
ight just making sure you knew that cut it seemed that your were a NOOB no offinese
but regarding your question it shouldnt have oil in the intake at all
as for cleaning it just soak it in hot water for a bit and use some DAWN that gets rid of oil pretty good let it dry and put it on
Old May 27, 2009 | 12:01 AM
eljoker's Avatar
also all TT kits ive seen eliminate the z tube all together and use a hard pipe from the intercooler to the TB
just thought id mention it
Old May 27, 2009 | 12:39 AM
Swivel's Avatar
Moderator
yeah, seems odd. Can you post a pic of the Z tube? Let's make sure you got the right piece there...
Old May 27, 2009 | 01:39 AM
thatsmyG35's Avatar
why does this TT Z have a stock Z tube?
Old May 27, 2009 | 01:56 AM
dineth00i30's Avatar
wtf did the owner of the TT Z did to his car?
Maybe he is selling parts bcus his engine is toast now.
Old May 27, 2009 | 05:05 AM
ttrank's Avatar
Grocery getter
That's not right, you have to get air from the turbos to the manifold so there is no way the stock intake pipe could be kept.
Old May 27, 2009 | 06:10 AM
Blue Dream's Avatar
I drove ttrank's car solo
This is getting good.....
Old May 27, 2009 | 01:11 PM
Xet's Avatar
Xet
lol
Old May 28, 2009 | 02:24 AM
O4G_ride's Avatar
so what's next?
The tube looks just like a z-tube... Okay... well, I cleaned it with some intake cleaner (since it's a "intake") I sprayed the clear liquid cleaner inside of the tube and it obviously dripped at the opposite end and came out brown then turned goldish... My question is: How dangerous is it if any oil enters my engine?
Old May 28, 2009 | 09:39 AM
EL-EE-ES's Avatar
sounds like the person may of over oiled the air filter. this is bad since it can clog up your sensors. just clean it very good and you should be ok...
Old May 28, 2009 | 10:17 AM
Xet's Avatar
Xet
^i agree
for whatever reason this tt z was running the stock intake, it sounds like it just is extra oil. it happened to my old car's injen sri. Just clean it up and make sure the filter isnt too oily and youre fine.
Old May 29, 2009 | 01:32 AM
O4G_ride's Avatar
its all g double o d, good
All right fellas. Imma do what you all said... thanks a milli.
