best Y pipe?
Old Jun 2, 2009 | 05:45 PM
Krispyklene's Avatar
best Y pipe?
i currently have a nismo s-tune without the y-pipe. does anyone have any recommendations on what y pipe i should run ?
i'd like the best performance for the money... i'd also like to make sure it would bolt right up to my midpipe. anyone have any suggestions or know where i can purchase these y-pipes... i'd perhaps be interested in the nismo y-pipe but where can i find one? i'm very open to other brands as well.
Old Jun 3, 2009 | 12:41 AM
tblazing's Avatar
i heard good things about the motordyne xyz pipe
Old Jun 3, 2009 | 09:42 AM
coup de grace's Avatar
+1 on the XYZ.
Old Jun 3, 2009 | 09:59 AM
ratm68's Avatar
i'm pretty sure performance difference is very mimimum on a y-pipe. It's just the brand and how much you're willing to spend. Don't buy into the bling of the y-pipe, nobody ever sees it. Try to get an HR pipe, i heard it fits and works well.
Old Jun 3, 2009 | 10:55 AM
twin001's Avatar
Motordyne XYZ without a doubt. Tony researched different merge locations and found there was a large difference in both sound quality and power depending on where the exhaust stream merged. Plus, the system is modular, you can run a straight pipe or a hi-flow cat in it.
Old Jun 3, 2009 | 11:46 AM
Jeff92se's Avatar
Red Card Crew
Motordyne XYZ. BUT his stuff uses V-Band clamps not flanges. I'm pretty sure if you went with his Y pipe, you have to get the connection to your exhuast cut and a V-Band flange welded in. Not a big deal considering Tony's stuff actually makes power.
Old Jun 3, 2009 | 01:12 PM
twin001's Avatar
Not true. The XYZ pipe has 2 THICK flanges to attach to the cats and another THICK flange to attach to the midpipe. The v-band is what is used to attach the module section to the forward part of the XYZ pipe. The v-band never connects to OEM (or aftermarket) exhaust components. Look at the pics on motordyneengineering.com and you can tell.
BTW, I have the XYZ pipe with the NISMO exhaust. The only mod was the 8" extension piece for the NISMO, but you need that regardless of what y-pipe you use.
Old Jun 3, 2009 | 01:15 PM
Jeff92se's Avatar
Red Card Crew
Thanks!
Old Jun 3, 2009 | 11:50 PM
DaveB's Avatar
For the cheap, go with the 350Z HR y-pipe. For true gains, the MD Y-pipe is the way to go, but expensive ($420). If I see a couple more dynos showing legit gains with the MD y-pipe, I'll probably get it.
Old Jul 14, 2009 | 03:36 PM
three.five's Avatar
I just picked up an 06 sedan 6mt.... my questions are:
Since I have the HR engine, do i have the HR y-pipe? or is that just coupes?
What is the purpose of putting a resonator or cat on the MD XYZ pipe if you have two cats prior to that? sound?
Tried a basic search and will continue to look, but thought i would through that out there while i look...
Old Jul 14, 2009 | 04:08 PM
LightsOut's Avatar
SIETESG
sorry but 06 sedan doesnt have an hr motor...only 07-08's
what you have is a rev-up motor
OP - Get HR yipe or like others stated xyz pipe
Old Jul 14, 2009 | 04:18 PM
three.five's Avatar
^^^thank you for the clarification, so the HR y-pipe would be an upgrade for me???
Sorry OP, I have similar goals as you in getting some power and sound without the rasp...
Old Jul 14, 2009 | 04:34 PM
LightsOut's Avatar
SIETESG
dont wanna say its upgrade as power wise, but you can feel the difference of the vehicle when driving. For me it I felt the gains in 5th and 6th gear they felt much more smoother and the car picked up a little quicker, also the exhaust note went up in sound.
overall easy good buy and is oem
there is a whole thread based on the HR ypipe.
you should pay no more than 100 for it, unless it needs to be shipped
Old Jul 14, 2009 | 04:37 PM
Calvin's Avatar
Overglorified Altima
Jic.
Old Jul 19, 2009 | 02:15 AM
Tollboothwilley's Avatar
XYZ pipe from Motordyne is awesome.
I love it.
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
