Intake for '06 Coupe 6MT
Old Jun 16, 2009 | 03:13 PM
four_am33's Avatar
Hi All,
I've been researching and would like to receive your input.
I've been reading nothing but good things about the MREV2 + 5/16ths spacer and plan on making these additions to my coupe.
I've been debating as to which intake would best suit this combination: The z-tube/k&n drop in filter combo or the stillen hi flow intake w/z-tube.
I've heard that the stock '06 airbox coupled with the z-tube/k&n drop filter has produced some of the best dyno results. What then would justify the exta $100+ for the stillen setup?
Thanks and I look forward to suggestions!
Old Jun 16, 2009 | 03:31 PM
Beebo's Avatar
Keep your stock airbox and get z-tube/ K & N drop in filter. save that $200 and put it towards the MREV2 + 5/16ths spacer
Old Jun 16, 2009 | 04:10 PM
RAF702's Avatar
Though running stock airbox, z-tube with K&N drop in filter will net you better dyno gains. But it's noticable again that you will feel when you drive. You might as well put a z-tube and jwtpopcharger. And save up for mrev2 plus 5/16th spacer, that's what im saving up for.
Old Jun 16, 2009 | 04:12 PM
Beebo's Avatar
Great for noise thats about it no power gains and the heat soak is horrible the stillen has a much better heat shield
Old Jun 16, 2009 | 04:34 PM
irishsig's Avatar
+1, this is the best setup with MREV2 & 5/16 spacer and it will cost you the least.
Definetly best bang for your buck.
Old Jun 16, 2009 | 10:12 PM
stock G's Avatar
As a proud owner of a 06' 6mt coupe, I highly recommend motordyne's MREV2+5/16 spacer and z-tube.
The stock air box that is already equipped with the 06' 6mt models, works pretty good. I would leave it alone. I still use paper air filter for personal taste only. As long it is clean(or replaced on time, maybe early than normal), your safe. Guaranteed no clogged air-flow sensor problems.
With these items, you can't go wrong. Sure, there are better things out there when dealing with mild breather mods for your 06 6mt, but it is a personal taste stand-point, but guaranteed satisfaction.
That is good you've been reading past and present postings about what your actually looking for. I do hope this and other postings have helped you decide: "What do you want to do to compliment your 06' 6mt???"
Old Jun 16, 2009 | 10:45 PM
four_am33's Avatar
Good to hear that this setup works well...even with a normal paper filter which is what I was considering doing as well.
As cash is a bit tight, i thought I'd start with these consensus best bang-for-your-buck upgrades. Later is anybody's guess... I'm hoping to put a Stillen catback exhaust as the next step
Old Jun 19, 2009 | 02:14 PM
SILVER04MT's Avatar
I just about lost my mind searching for the "best intake" when I was trying to make that decision. It seems every solution out there has one (or more) of the following drawbacks:
1. expensive
2. loss of power due to heat soak and no separation between filter and engine bay
3. no "aggressive sound" from the intake
I ended up going to a local shop and asking their opinion- they built an intake for me using the OEM airbox. Basically we added a polished metal pipe with rubber hoses and clamps to replace the "g-tube", they improved the airbox by making some modifications to pull in more cold air and keep engine bay air out. Then the modifications they made to the airbox allowed me to run a 6" K&N cone filter. I can honestly say none of the drawbacks above applied to my setup and I love it!
Old Jun 19, 2009 | 03:17 PM
Jeff92se's Avatar
Red Card Crew
You got pics of that? I find it difficult to believe you got a 6" dia cone filter in there but pics are worth a 1,000 words.
Old Jun 20, 2009 | 01:44 AM
silver g's Avatar
I ran the Stillen Intake with stillen Z tube for 3 or 4 years and I would say other than sounding cool it did absolutely nothing for the car (maybe 1-2 more HP). K&N drop in and z tube is most likely a better route...but do not expect to see big gains regardless of which way you go. You will prob get more bang for your buck with the MD spacer and MREV.
Old Jun 20, 2009 | 01:55 PM
Beebo's Avatar
1. expensive
Pics?
Old Jun 22, 2009 | 05:29 PM
Bestswat's Avatar
Go stock with K&N, save your money for the spacer and mrev. People have gain 20whp and 20lbs of torque with that combo. If you want some noise later down the road then get the intake.
Brodys_GCoupe
Nov 7, 2015 08:06 PM
Vqsteve
Jul 30, 2015 02:25 PM
Kal Hamm
Jul 24, 2015 08:55 AM
driftsucky
Jul 15, 2015 12:38 PM
