G35 High Flow Cats And Test Pipe
Old Jul 12, 2009 | 08:45 PM
seymore4's Avatar
m56
You'll understand a lot better when you pull your cats out. I was pretty amazed how heavy and clunky they are... almost like sticking a big-*** cork in the exhaust pipe.
The way to go is a true dual cat-back exhaust AND HFC's/ test pipes... It makes a serious difference.
Old Jul 13, 2009 | 10:32 AM
Spike4841's Avatar
so Test pipes to replace the Cats, take out the resonator and muffler and just have a straight pipe going all the way back
Old Jul 13, 2009 | 01:29 PM
seymore4's Avatar
m56
...Probably gonna sound like **** and have a lot of rasp.
Just pick up a used exhaust if you don't have the money for a new one...
Old Jul 13, 2009 | 07:34 PM
caketech's Avatar
Originally Posted by CltCoupe07
Yeah, I understand that the cats are very restrictive/dense... I'm not all too familiar with the G35 exhaust set up yet (noob to the Gs ). But you know, closer to the exhaust valves you are in the system, the hotter the exhaust, so I would think the further it gets away and cools off (and then expands) you would want the piping to get progressively bigger, and so I was thinking that if HFCs for the Gs have bigger inner diameters than OEM, and then you go from let's say a 3" HFC to a 2.25" catback section, it would be a restriction in the system.
But, if the cat honeycombs are a much bigger impediment to flow than just sheer diameter, that would make sense.
What you're saying actually is true and makes a lot of sense, but the reality is, even though you're bottle necked on the way out, the affects of having larger piping somewhere in between will help with flow, sorta why a lot of FI guys wil go 3-4" downpipes even though their exhausts are only 2.5-3" in diameter.
also depends on material inside the oem cat, i assume it's quite restrictive, but haven't seen it yet.
Old Aug 17, 2011 | 04:16 PM
SuperTrooper699's Avatar
I got 03 sedan with test pipes and a coupe mid with no muffler exhaust wise. Test pipes since they have no resonator they make a raspy sound. I know high flow cats don't do that. So I kinda wanna switch. But my question is wouldn't test pipes give your more hp and flow then high flow cats? If so I would rather save up for cat back exhaust if that would take the rasp away?? Ps. Just upgrading cats in general with a intake "350z z tube with pop charger" you will feel a difference!
Old Aug 23, 2011 | 08:48 PM
GXXXV X's Avatar
^^try ART pipes!!
Old Sep 15, 2011 | 05:02 PM
that1buffguy's Avatar
I know this is kinda old but oh well. Just so everyone knows, freeing up more air flow on either side will only provide a small increase in power (on G35's), not the huge gains most people expect or hope for. Breather mods make a much larger difference on FI applications than NA. On NA cars, a certain amount of backpressure from the exhaust side is necessary to retain low end power, so, that being said, these exhaust mods might make for a small amount of top end increase, but they could lose just as much on the bottom.
Old Sep 15, 2011 | 06:35 PM
gary c's Avatar
Not bad for your first post....^....This is why if you have a first gen G35 it's important to have the best high flow intake along with MotorDynes spacer (bigger the better) to get all the air in as quickly as possible. With HFCs like BERK'S you've cut down major restriction, just check out what the OE cats look like....would anything get thru that maze? The last part is to add a high flow dual cat back exhaust. The rewards in making the mods listed with a N/A VQ motor s/b very close to 25 RWHP with a tune. BERK'S HFCs will pass the sniffer test here in CA., my smog tech never looks under my coupe he's just interested in results!
Gary
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
