PROS/CONS of MD 1/2" spacer vs 5/16" spacer
Old Aug 25, 2009 | 03:12 PM
| 1cleanG |'s Avatar
Cool PROS/CONS of MD 1/2" spacer vs 5/16" spacer
Looking to get a Motordyne spacer for my first engine mod for my coupe!
Has anyone had experience with both, or does anyone have comparison of the two for gains? Looking at the site I see the 1/2" is about a 2hp comparison with a louder roar, but does anyone have anymore experience with actualy Dynos to show actual #'s?
thanks guys!
Old Aug 25, 2009 | 03:21 PM
Jeff92se's Avatar
Red Card Crew
As the reply from the other thread said, go to their site and examine their dyno charts. It's not going to get any better/non-partisan than that.
Old Aug 25, 2009 | 03:27 PM
| 1cleanG |'s Avatar
i went to the site but don't see a dyno for the 1/2" which is why i posted. They only have a dyno of the mrev2 with and without the 5/16 spacer.
Old Aug 25, 2009 | 03:29 PM
Jeff92se's Avatar
Red Card Crew
It's on the first dyno sheet in the dyno section. Look harder
Old Aug 25, 2009 | 03:30 PM
| 1cleanG |'s Avatar
LOL...didn't look under "DYNOS"...oops. only looked at the link by the actual products. Thanks though :-)
Old Aug 25, 2009 | 03:40 PM
| 1cleanG |'s Avatar
Your right..peeerfect chart.
SOOO, any preference between the two? Seems the 1/2" would only be beneficial in torque gains. The HP kind of even one another out through shift points.
Old Aug 25, 2009 | 04:18 PM
Jeff92se's Avatar
Red Card Crew
I suggest taking a look at the delta change graphs. Or the graph where the red line = stock and is flat. And the rest of the chart shows the delta hp/trq changes though the rpm range.
Old Aug 25, 2009 | 06:07 PM
Xet's Avatar
Xet
uhmm 5/16 spacer... simple question
Old Aug 25, 2009 | 06:10 PM
OCG35's Avatar
Old Aug 25, 2009 | 07:50 PM
| 1cleanG |'s Avatar
Never thought about if I wanted a strut bar I'd need to stick to the 5/16 as well. Hmmm
Old Sep 28, 2009 | 07:42 PM
Dragon35's Avatar
So, you cant use a strut bar with the 1/2 inch spacer?
Old Sep 29, 2009 | 12:04 PM
Hydrazine's Avatar
No, not unless its a strut bar that goes in front of the plenum assembly.
Old Sep 29, 2009 | 06:18 PM
Dragon35's Avatar
is there a strut bar that goes in front of it?
Old Sep 29, 2009 | 06:37 PM
Tollboothwilley's Avatar
You can use the 1/2" with a strut bar. I have the NRG bar. Several options will work with the 1/2" bar but coupe engine cover won't work with the 1/2".
Old Sep 30, 2009 | 02:35 AM
Killjulez's Avatar
^^^^ I was able to install the 1/2" spacer on my coupe and keep the engine cover on, no problem. i do not have a strut bar though.
