Pipe Dreams
Old Sep 7, 2009 | 04:44 PM
  #106
rookie's Avatar
Yup, normally pointed towards the rear since the oem hose is coming from the rear. We figured this was the best way to make sure the ARC guys were taken care of. The area behind the throttle body is tight so a -8 or -10 steel braided line is stiff at that radius.
Old Sep 7, 2009 | 05:22 PM
  #107
OCG35's Avatar
swivel fitting (like the CF tubes)
kidding... there are probably far more using the OEM pcv hose so hopefully the standard orientation will be suitable for most.
Old Sep 7, 2009 | 05:27 PM
  #108
rookie's Avatar
Steel braided stiffness can eventually beat up the rubber seal or whatever is used on those fittings unless you tie down the hose or something, it doesn't really move but why have another point of failure on the pipe when you can just have it welded and be done with it.
Old Sep 7, 2009 | 05:31 PM
  #109
OCG35's Avatar
^^^ I guess you didnt read the "kidding" part.
Old Sep 7, 2009 | 05:37 PM
  #110
rookie's Avatar
Nope, still answering your point. Kidding or not, no reason not to address it.
Old Sep 8, 2009 | 02:37 AM
  #111
rookie's Avatar
Almost ready for the GB. Here's another install, with a Kinetix. Plenum mounting tab was cut off on this one.
Old Sep 8, 2009 | 02:52 AM
  #112
sammy_G's Avatar
^--- love the lipstick dip stick
Old Sep 8, 2009 | 09:45 PM
  #113
rookie's Avatar
Rev up engine bay
So it clears pretty much everything tested so far.
ARC/NRG STB, RA STB, Stillen STB, done on Kinetix plenum, done with oem plenum, done with Cosworth plenum.
Tamper proof T20 bits ordered so they can be included for installation ease.
Old Sep 8, 2009 | 09:52 PM
  #114
CandlestickPark's Avatar
ill Sedan
Very nice. Including the T20 tool is a very good move.
Old Sep 9, 2009 | 01:48 AM
  #115
Beebo's Avatar
Can you make some type of heat shield for this?
Old Sep 9, 2009 | 09:02 PM
  #116
Beebo's Avatar
Originally Posted by beebo
can you make some type of heat shield for this?
Old Sep 9, 2009 | 10:48 PM
  #117
rookie's Avatar
We won't be making one, just drive faster. Heat is only an issue in traffic. How much power do you need in traffic?
Don't crucify me, this is an aesthetics option over other short ram type intakes. Injen heatshield probably does little to nothing.
Old Sep 9, 2009 | 10:50 PM
  #118
vash_g35's Avatar
IMO, its looks busy with a heat shield. So, it looks cleaner without one.
Old Sep 9, 2009 | 10:54 PM
  #119
Beebo's Avatar
Fine ill drive faster but you have to pay for my speeding tickets
Old Sep 10, 2009 | 12:52 AM
  #120
bigc's Avatar
Wings Nation
...Injen heatshield probably does little to nothing.
watch it buddy!
