Fast Intentions HFC question
Old Aug 29, 2009 | 12:35 PM
Gtrpnoyracer's Avatar
Question Fast Intentions HFC question
Would anyone know if FI HFC are good on an HKS Exhaust system to give that lower sound on idle also would make the exhaust quite louder that usual? let me know, thanks
Old Aug 29, 2009 | 12:41 PM
Calvin's Avatar
Overglorified Altima
I had this exact same setup and I loved it. When you stomp on the gas, it's most definitely louder than without the HFCs. Cruising and idle sound is about the same.
Old Aug 29, 2009 | 02:14 PM
oh okay.... so do you know how much these FI HFC cats are and would the #'s for cells matter? easy or hard to install? thanks for your opinion
Old Aug 29, 2009 | 02:16 PM
Tollboothwilley's Avatar
Cell # changes the ability to flow and ability to reduce emissions.
FI cats new are between $500-600 normally.
Old Aug 29, 2009 | 04:27 PM
GJ Hazlett's Avatar
Watch out for drone! I don't have the HKS but as soon as I installed the Berk HFC's I had drone at 1600-2000 RPM's.
As far as install there are 3 studs on each header that 2/3 have to be removed and on the third stud just the nut comes off...I learned this one the hard way. You will need extensions as well as a universal .
Old Aug 29, 2009 | 07:39 PM
so the higher the number is there going to better flow and reduce emmisions or is it that if its like lets say 300 cell, the flow is not as good and more emmision?
lmk thanks again
Old Jan 21, 2010 | 02:41 AM
bump... need help on this ^^^
Old Jan 21, 2010 | 03:49 PM
tiguy99's Avatar
lmk thanks again
Actually its the other way around. The more cells the more items to restrict airflow.
Yes more cells help clean the air and help with emissions but they restrict airflow and that robs you of horsepower
Thats why most guys who go FI ditch cats all together and either run test pipes or straight pipes.
If you need HFCs, I'd grab 300 cell and call it a day. I've had 300 cell Berk HFCs for a year and passed emissions last summer with flying colors.
Old Jan 22, 2010 | 12:46 PM
davesxx01's Avatar
Ditto! Sadly
My drone area is at 18-2500 rpm! Never had a problem with drone until I added the Berk.
Old Jan 22, 2010 | 02:45 PM
liche's Avatar
If you get the HFCs make sure you get the extra bungs installed. I'd get an extra bung installed on each one. This way you add an A/F in the future or use an extra port for tuning (external A/F)
Also make sure the bungs are installed on the topside of the HFCs - specifically request this. You don't want to have permanent O2 sensor installed at the bottomside where it can collect with condensation.
Gip
Aug 24, 2015 05:31 PM
linedr89
Aug 17, 2015 05:11 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
