Help~~ Accident occured during install
Old Aug 31, 2009 | 06:19 PM
Tree_tech's Avatar
Hi, I was installing Z-tube and I accidently dropped the bolt inside the hood. Size is about 1.5~2cm. I dropped it near the air box duct. Do you guys think I will be ok? When I dropped it, sounded like it's got dropped twice inside.
Old Sep 1, 2009 | 12:31 PM
Tollboothwilley's Avatar
You should be able to find the bolt...
Remove the intake. Otherwise, the bolt will probably just fall out while you are driving.
Old Sep 1, 2009 | 04:45 PM
Tree_tech's Avatar
Thanks~
Old Sep 1, 2009 | 10:44 PM
OCG35's Avatar
keep a telescoping magnet in the glove box.... that, a 1/4" drive 10mm ratchet, small pliers and a universal screwdriver is about all you need for most items in the engine bay (for quick fix/swaps) - they all fit in the glove box with plenty of room for other stuff.
anyway - get yourself a telescoping magnet for future instances... a quick fish in the general location that it fell will almost always get it.
Old Sep 1, 2009 | 11:01 PM
MobbinTehG's Avatar
Good call.
Old Sep 1, 2009 | 11:38 PM
Tree_tech's Avatar
wow, thanks for the info.
Old Sep 2, 2009 | 06:48 AM
Blue Dream's Avatar
I drove ttrank's car solo
It might just be sitting on the underside cover. Take out a couple of bolts down there if the magnet doesn't work and look for it.
baker2795
Sep 2, 2015 06:00 PM
DimQ
Aug 14, 2015 02:04 AM
Team STILLEN
Aug 10, 2015 08:17 PM
chinee
Aug 8, 2015 10:11 AM
