Exhaust DIY help
Old Sep 1, 2009 | 10:24 PM
Mercinator's Avatar
Exhaust DIY help
can anyone point me in the right direction of a DIY for exhaust and an extension?
please lemme know
Old Sep 2, 2009 | 01:05 PM
TroysG's Avatar
what exhaust?
each have their quirks
Old Sep 2, 2009 | 03:25 PM
Mercinator's Avatar
Single Agency Power Exhaust
i need to use a extension with it (I have the extension)
Old Sep 6, 2009 | 11:37 PM
TroysG's Avatar
if you can get access to a lift or a pit it makes it HELLA easy.
first thing you'll need is a either a strong arm or an impact gun. I believe the right sized socket is 17mm. and a wrench of the same size. just take the exhaust off piece by piece. and then reassemble with the new one. you may be able to take a piece off put a piece on depending on the design of the exhaust.
When removing hangers from rubber brackets I'd recommend using lots of wd40, let it soak in for a while then be prepared to pull and push like you never have before... using a screwdriver for leverage is highly recommended on those
gatorglaze
Sep 19, 2015 12:06 PM
Jon81035
Sep 16, 2015 04:58 PM
Albanian122
Sep 12, 2015 04:02 PM
