MREV2 & spacer installed, dyno failure. Help!
Old Oct 3, 2009 | 12:02 AM
tragedycat's Avatar
Originally Posted by davesxx01
Cam sensor? Wow! I can't see how that would turn on the slip & ABS lamp while dynoing (Vdc already on) but who knows?
That's why I'm asking!
I don't know anything about dynos so if it's normal for those lights to be on during runs, then just ignore my post! I thought you meant it would just light randomly when you gave your car gas.
Old Oct 3, 2009 | 02:33 AM
Hydrazine's Avatar
Hi Dave,
It was good talking with you on the phone today. I'm always available to help out.
If your baseline was significantly lower than the average Z or G measured on that dyno, it suggests something else is going on. Particularly if each successive dyno goes down. Assuming a proper installation, the MREV2 will never cause results to move around.
Have you been able to find anything new? I would check the catalytic converters to make sure they are still working good and also check the other things we discussed.
Maybe we can figure out more clues from your other test plot's and the plots generated by similar Z's and G's that were tested on that same dyno.
It would help to have a relative reference point.
Also, here are the links we talked about.
https://g35driver.com/forums/g35-cou...-ignition.html
https://g35driver.com/forums/intake-...ugs-stock.html
Old Oct 4, 2009 | 01:07 PM
davesxx01's Avatar
Found another thread that suggests unpluging the yaw sensor for full TCS disable. Is this what people do when dynoing?
Old Oct 4, 2009 | 04:25 PM
Hydrazine's Avatar
For the most part, no. The TCS is usually not an issue when doing dynos.
Old Oct 4, 2009 | 05:38 PM
officerdbag's Avatar
Just an FYI if it helps.. When I dynoed my car with VDC off the SLIP light kept blinking at me an abs came on too.
Old Oct 4, 2009 | 10:50 PM
Hydrazine's Avatar
ABS should definetly not be on. That will reduce power for sure.
But it usually doesn't do this on the dyno... There may be some kind of electronic issue. Or something related to the ABS sensors.
Can you get diagnostic codes?
Old Oct 7, 2009 | 02:34 AM
otd34's Avatar
or maybe their dyno's broken...
can you tell that your car has lost power? or does it feel the same?
Old Oct 7, 2009 | 11:38 AM
davesxx01's Avatar
Their dyno isn't broken. Ran 3 other cars on it just fine since. I ordered Cipher as I beleive I have a Gremlin in the wireing!
My car runs great on the street, just added MD's XYZ pipe and the closeout Stillen single exhaust and love the way it purrs now. The bump in topend power dosent hurt either!!
Old Oct 13, 2009 | 12:39 PM
Tollboothwilley's Avatar
Those lights trip often if your car isn't square on the dyno. Driving normally for a short period of time will turn them off.
My guess is that your VDC limited the output on the dyno.
Old Oct 13, 2009 | 01:47 PM
sloppymax's Avatar
It has been a while but I am positive my slip light came on and pretty sure that my ABS illuminated at the end of my 4 runs. It was almost 2 years ago but my power output was not affected and was pretty standard numbers for running on a dynojet 248.
To the OP, you showed the pics of the plugs but did not mention if they were replaced or simply pulled to inspect. If they were replaced, did you use OEM ngk plugs in the stock heat range?
Old Oct 13, 2009 | 02:40 PM
davesxx01's Avatar
Yes, I used stock OEM NGK replacement plugs.
Updates are:
I went to another shop and had a smoke test preformed on my install. No leaks were found and the car deffinately feels stronger. I've added the XYZ pipe with resonator and a Stillen single exhaust.
Car runs really good but I still have some knock at WOT. Front brake pads are paper thin so I ordered some Hawk pads.
Also ordered Cipher to datalog but havent received it yet.
Still think I have a gremlin somewhere but I know that it has nothing to do with Motordyne products!
Old Oct 27, 2009 | 12:20 PM
davesxx01's Avatar
Update.
Tried LFR5A-11 copper plugs. Gapped to stock. My pinging went away! Talked to the guys at UpRev and Tony at MotorDyne and came to the conclusion that with the fuel available here, Platinum plugs just dont work!
I will go back to dyno again soon but my butt dyno likes the feel and obviously so does the ECU!
I do need to get a tune though as it's a little to lean.
Old Oct 28, 2009 | 10:01 AM
R35SEDAN's Avatar
Hey, I have seen all those lights come on. If you take out the VDC fuse they all freak out... they stay on till battery is disconnected and then even once the cars been restarted they stay on till you move it around a bit...
Old Oct 28, 2009 | 12:41 PM
If you were pinging that would cut back power for sure. Good to know that the copper plugs are working out for you. I believe Ttrank runs copper tip in his car.
jsimonk
Dec 22, 2023 03:49 PM
Raven7
Aug 14, 2015 04:40 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
