Fujitsubo y-back Motordyne XYZ & Fast Intentions resonated test pipes
Old Dec 8, 2009 | 05:20 PM
solobaric's Avatar
I first installed the Fujitsubo Legalis exhaust with the Motordyne XYZ pipe with straight pipe module. I liked it a lot; the looks, fit, and overall quality are very good to me. It performed great too on its own, I noticed an improvement throughout the power band. I would have been satisfied but the sound was just a touch too quiet for me.
I knew this could happen going into it but I chose to start out quieter instead of louder with the option to make it louder and faster if needed. After much deliberation I decided to install Fast Intentions resonated test pipes and add the cat module from Motordyne in the y-pipe.
The result is pretty much perfect for me. It sounds nice and deep at idle and not too loud unless you get on it. The best way I can describe it is an aggressive metallic sound as the RPMs build. The overall db level is increased a good amount. In person and under normal driving conditions there is zero rasp. There would definitely be too much rasp for me without the cat module. Actually, throwing in the MD resonator module would probably sound optimal to me but I wouldn't want the odor so cat module it is.
There were no fitment issues except a little high temp silicone between the midpipe and y-pipe.
Old Dec 9, 2009 | 09:57 AM
viceversa's Avatar
what configuration do you have installed on that sound clip? is that with test pipes and motordyne HFC? I have been thinking about going that same route. Can you do a sound clip of WOT from a stand still?
Old Dec 9, 2009 | 10:46 AM
solobaric's Avatar
The clip includes the Fuji exhaust, MD XYZ w/cat module, and FI resonated TPs.
Old Dec 9, 2009 | 01:02 PM
Tollboothwilley's Avatar
Need to hear that car under load...in motion. and from inside the cabin as well
Old Dec 10, 2009 | 11:29 PM
Calvin's Avatar
Overglorified Altima
Too high pitched/raspy for my tastes. Then again, like you said, it may just be a poor clip.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
NohoG35revup
Aug 22, 2015 12:13 PM
linedr89
Aug 17, 2015 05:11 PM
andresito7
Aug 1, 2015 04:53 AM
