plenum screwups
Old Dec 29, 2009 | 11:45 PM
Hydrazine's Avatar
Yes. Everything you need for a complete install. The only thing you need to supply is the tools to install it.
Old Dec 30, 2009 | 01:54 AM
Tollboothwilley's Avatar
^ and you can easily do it with a 10 mm socket wrench, extension and a flat head screw driver (for the g/z tube.
Those are the only tools I use I've never used a torque wrench and I've never had problems.
Old Dec 30, 2009 | 01:23 PM
OCG35's Avatar
need pliers too.
Old Dec 30, 2009 | 01:29 PM
verilath's Avatar
ive snapped the head off the bolts while torqing them down. not because I over torqued them, but just because i was using too short of a wrench and the angle i was standing at. go slowly and tighten in steps. 3-5 passes of tightening the bolts is best to assure they are all evenly seated
Old Dec 30, 2009 | 01:36 PM
kennymo's Avatar
alright. i still havnt gottin around to installing this. i still havnt had any extra money to order some of the little plastic spacers. (bought mine used and it didnt come with any) but i am glad you guys have kept this thread going.
Old Jan 23, 2010 | 06:23 PM
G35CDriver's Avatar
I guess you would have to contact the dealer for an extra lower manifold bolt??
Old Feb 15, 2010 | 01:02 PM
SedanManBen's Avatar
I feel like this is is a good thread to keep going. Because I made both major mistakes.
Mistake number one:
Dropped the plastic bolt spacer into the lower plenum..and that's it resting on a valve!! (closed thank god)
Mistake number two:
Because I had to remove the lower plenum to fish out the plastic piece... while putting it back together I used an in-lb torque wrench and was torquing the first bolt to 40 inch-lbs like the manual says.. and SNAP! broke a bolt Realized I didn't have the torque wrench set correctly so it was acting like a ratchet. Just be patient everyone and all other new guys out there!
Old Feb 15, 2010 | 01:05 PM
kennymo's Avatar
oh dang thats not good.
i finally got mine installed about a month ago. i love it. my instal went very smoothly and quickly thankfully.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
Oggie.mayes
Sep 27, 2015 04:10 PM
