different kinds of intake pictures ...
Old Feb 13, 2010 | 06:34 PM
  #31
OCG35's Avatar
Originally Posted by nfsp1
why you rolling your eyes?... I just emphasized the "little" more sense part... 'cause it's not much better...
Old Feb 13, 2010 | 06:44 PM
  #32
NFSP G35's Avatar
? = 2B || !2B
^I'll roll my eyes at you if I feel like it!!! Or are you going to get 'butt hurt'???
Old Feb 17, 2010 | 02:22 PM
  #33
Ludafish's Avatar
I am in the process of putting together my intake system. Just picked up a Z tube and thinking of adding the Stillen intake/box with it. Anyone know how long this takes to install and can I do it myself easily? Should I run another filter/airbox? Thanks for the help.
Old Feb 17, 2010 | 02:37 PM
  #34
OCG35's Avatar
same combo as the pic I posted on previous page... easy install - 20 min maybe (if that)
Old Feb 17, 2010 | 03:14 PM
  #35
officerdbag's Avatar
Thats a good combo.. I have read that the Pop charger filter should be used as its better than the stillen filter. But retain the stillen airbox
Old Feb 17, 2010 | 03:21 PM
  #36
Ludafish's Avatar
So I am guessing that the two filters are interchangeable? I like the factory look/function of the Stillen box, so i am going with that initially, then switch the filters out later on. I was reading the other thread about rubbing on the A/C hose...is this a problem with the Z Tube/ Stillen airbox combo? Thanks for the info.
Old Feb 17, 2010 | 03:32 PM
  #37
Ludafish's Avatar
Oh nice ride...is that the Stillen airbox? Did you have any spacing issues with the A/C line as I have heard on other threads? Glad to know this was 20 min worth of work.
Old Feb 17, 2010 | 03:37 PM
  #38
OCG35's Avatar
yes - Stillen and Pop Charger are interchangeable... I use both...
the edge of MAF housing sometimes rubs on the ac line... some do, some dont... there is very little space there, so tolerances of only a few mm can make a difference... just use split rubber hose and you'll be fine.
here's an example... for some reason different configurations (even different angle of MAF sensor) have made the contact point in different places... I've had the ac line hit the end edge too... right now it's only resting on the side - you can see the split hose in this pic:
Old Feb 17, 2010 | 03:43 PM
  #39
OCG35's Avatar
thanks... yes it's Stillen (cosmetically modified)... the ac line issue is addressed above...
Old Feb 17, 2010 | 04:50 PM
  #40
Beebo's Avatar
Furookie FTW
Old Feb 17, 2010 | 04:58 PM
  #41
OCG35's Avatar
Originally Posted by Beebo
Furookie FTW
for looks, yes - for performance, no.
Old Feb 23, 2010 | 04:09 PM
  #42
CERBERUSlucid's Avatar
Polished Upper,and throttle buy xSxExCx, Polished MREV2 and 1/2" MD Spacer buy me. Fujita Bronze Intake and the catch can is in progress.
RA081024
Aug 18, 2015 07:03 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
