NEED HELP!! Test Pipes
Old Feb 18, 2010 | 11:22 AM
amracer's Avatar
Hey guys i need your help I"m planning on buying some test pipes but was wondering if I would get any check engine lights coming on , also I would like to know if anyone has a sound clip of a sedan with stillen gen2 and test pipes so I could have an idea on how it would sound Thanks for any help u guys could give me
Old Feb 18, 2010 | 11:36 AM
PAIXAO's Avatar
Here you go... test pipes but with a Stillen Gen I. I'm assuming it will not be quite as loud with a Gen II
<embed id=VideoPlayback src=http://video.google.com/googleplayer.swf?docid=3982113370550292352&hl=en&f s=true style=width:400px;height:326px allowFullScreen=true allowScriptAccess=always type=application/x-shockwave-flash> </embed>
Old Feb 18, 2010 | 01:39 PM
TofuProductions's Avatar
You'll have a cel (mine did even with the built in nonfoulers on my coupe's test pipes) so I got some o2 simulators, and problem solved, took my emissions test with them on and passed with no issues.
Old Feb 18, 2010 | 03:08 PM
ratm68's Avatar
a warning regarding soundclip for exhaust. Most people tend to capture the sound/video right after install. With any exhaust component and especially TP, it may sounds sporty after install, but that will change as fiber starts to burn off or wear down after initial "break-in", this is much more drastic with TPs. So it might sound good after install, but a month or two later, it might sound like a civic fart can.
Old Feb 23, 2010 | 09:53 AM
amracer's Avatar
Smile
So what do you mean by o2 simulators is that something u can buy? Also what brand test pipe has the least rasp if anyone knows thanks
Old Feb 23, 2010 | 03:26 PM
ratm68's Avatar
most test pipe is just that, a straight pipes. Then you have resonated test pipes with built in resonator, that would be the way to go to help reduce rasp. But often time, after burn in, you'll get rasp, maybe just not as bad as a simple straight pipe.
Old Feb 23, 2010 | 03:32 PM
If anything I thought during my break-in period it sounded a bit fart-can ish. But after that, I personally think it sounds deep and mellow at low rpms, then exotic somewhat at high rpms. Just check my youtube videos (in my sig).
To each their own though.
Old Feb 23, 2010 | 03:33 PM
The Stimulation's Avatar
CEL depends on which test pipes you go with. I have Kinetix non-resonated ones and they're not supposed to give a CEL light. I'm actually one of the rare cases (1 of 2 people that it's happened to). It's a simple fix, just get some O2 sensor extenders and you're fine if it does happen.
Old Feb 25, 2010 | 10:21 AM
amracer's Avatar
I heard from someone that the berks testpipes already have the cel fix welded in has anyone tried these out how is the rasp?
magnetism80
Jan 27, 2016 12:57 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
