Welding the Borla True Dual?
Old Oct 1, 2004 | 07:39 PM
TCFOOL's Avatar
Hey all just got my Borla True Dual for my G35 6MT Coupe. I was told by two friends that they would get it welded because it was a bolt on and there were so many places to leak....
Has anyone here done that and/or have any leaking problems with just a bolt on install?
Thanks for any time spent to respond..
TC
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old Oct 2, 2004 | 01:19 AM
roneski's Avatar
Devil's Advocate
Re: Welding the Borla True Dual?
If you torque to to spec and use the right gaskets it shouldn't leak. If you get it welded then its probably just as likely that one of the welds could crack, depending on the skill of your welder.
I haven't had any leak problems with my Fuji yet.
Old Oct 2, 2004 | 03:44 AM
Demonteverde's Avatar
Moderator
I agree with what Roneski said, just torque all the provided clamps to specification and you shoud have no leaks and make sure the h-pipe is pressed firmly together before you torque the clamp in between. Then check for any clearance issues with any of the pipes so no rubbing occurs (you'll hear it if it anything rubs - my right exhaust pipe did near the sway bar). I've had no leaks since I installed this exhaust.
If i'm not mistaken, Borla has that million mile warranty for our exhausts so if you weld anything you void it.
2K4 - 6 spd mt, diamond graphite coupe, z-tube, borla exhaust. Next mod: RT cats
Old Oct 2, 2004 | 06:41 AM
skeleton_cru's Avatar
Sedan
Some people used some type of sealant at the joints when they installed their Borla's. I don't remember what it was. Do a search and you'll probably find it. I didn't weld mine or use any sealants and I don't think I have any leaks.
Old Oct 2, 2004 | 04:29 PM
MOTOP's Avatar
cru,
Liquid Cement ?
That's what muffler shop used to install my y-pipe.
***04 G35s 5AT/Sport***
***04 Volvo XC90 T6***
Old Oct 2, 2004 | 06:39 PM
roneski's Avatar
Devil's Advocate
I used Permatex Hylomar HPF gasket dressing and flange sealant. Available at my local Autozone. They also make this stuff which would probably be ideal, but I didn't see it anywhere locally.
Old Oct 3, 2004 | 08:57 PM
Samstag's Avatar
I used Permatex #81878 "Ultra Copper" high temp RTV silicone on my Stillen. There were a couple of clamp joints with visible gaps that needed to be sealed.
Old Oct 3, 2004 | 09:01 PM
Samstag's Avatar
Found a pic that illustrates the problem (on a Stillen):
Old Oct 5, 2004 | 01:24 AM
TCFOOL's Avatar
I concur with all of your fine ideas.. I will intall with the clamps and use that muffler silicone or what ever it was and just keep checking it for the frist few weeks and retighten things as need be... I can't wait to have her low growl under me..lol
TC
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
NyCrAzY
Oct 1, 2015 09:19 AM
