Megan v2 test pipes, in cabin vibration and noise..
Old Aug 6, 2010 | 12:19 PM
FlatlandJu's Avatar
Hey, I've looked around to try and find a similar issue, but all people seem to be covering is the infamous hiss that the pipes let off.. That isn't my concern, my issue is that when the steering wheel is tilted about an 8th of a turn to the right, i get this super loud almost grinding noise sounding like it's coming from the steering wheel.. I've narrowed it down to the TPs because if I jam a piece of wood between the ground and give the pipes a firm hold, they no longer make the noise.. Just wondering if anyone has come up with any solutions for this that actually hold up. I was thinking of trying exhaust hangers, but i have no clue where I can mount them up in the first place.. Thoughts? Anyone experience the same thing?
Old Aug 6, 2010 | 01:05 PM
Tollboothwilley's Avatar
You could use the stock bracket and weld some tabs on to hold them in place. Very odd...I'm not convince that your TP are causing grinding noise in the steering wheel though.
Old Aug 6, 2010 | 01:09 PM
FlatlandJu's Avatar
I was thinking that could work, just gotta find those bolts that were holding it in in the first place. It isn't really a physical grinding in the wheel, that's just where it sounds like it's coming from, at a certain angle when turning. It happens in a different spot when on a slanted street, i think it's when the car is at a certain angle it makes the noise.. I'll take a sound clip when I get a chance
brownie
Nov 25, 2015 12:50 AM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
