APS Tall Boy
Old Dec 2, 2010 | 01:21 PM
CandlestickPark's Avatar
ill Sedan
Found it:
https://g35driver.com/forums/intake-...yne-setup.html
Originally Posted by gabe3d
Even though many users have previously posted about the Cosworth Intake Plenum not performing well on non-FI car, no one has really done a good before and after test. So a few months back I took the plunge and shelled out the premium to get one to hopefully gain some power over my Motordyne 5/16th and MREV2.
As expected from cosworth and any premium items, Build quality, packaging, and looks were top notch.
Installation of the unit was straight forward, other than three things.
1. My box didn't come with a manual so I had to get one faxed from the vendor.
2. Installing the gasket for the carbon cap is really a pain in the butt and would appear to be very susceptible to leaks.
3. The bracket on the passenger side carbon cap is not meant to last. It broke off right after I started the engine. Luckily it's not vital for the operation of the plenum.
After installation, the manifold definitely looks a lot nicer than the stock setup and clears the strut bar much better. Please ignore the dirty engine bay.
Aesthetics aside, how did it perform? Driving the car around a noticeable power loss can be felt down in the lower and mid range. I was quite disappointed to say the least but I never trust my butt dyno so off to the dyno it went. Below is a series of two different test comparing the Cosworth on a fully NA engine.
Based on these tests, it is apparent that the Cosworth is not suited at all for my application so back to the Motordyne setup it is. But I must say that the one performance advantage the Cosworth has over the MD is the ability to sustain power pass 6500rpm... to be continued.
Old Dec 2, 2010 | 01:26 PM
alfhasg35's Avatar
thankx.. there it is...
Old Dec 2, 2010 | 04:29 PM
Gee35init's Avatar
Thanks alot I really appreciate that, very informative!!
Old Dec 11, 2010 | 05:49 PM
bulletproofpat's Avatar
I would just go with a Motordyne spacer. I had the 1/2" and loved it.
Old Dec 13, 2010 | 11:12 PM
FenixL1P's Avatar
md spacer....
Old Aug 26, 2011 | 08:55 PM
jake.millz32's Avatar
What about comboing the mrev 2 with the spacer? Do you guys think that has better gains than the APS?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
Machine Head
Sep 4, 2015 07:22 PM
