Put a iso thermal plenum spacer in now i get worse gas milage????
Old Dec 10, 2010 | 10:59 PM
thescreensavers's Avatar
Mr.202?
Originally Posted by LightsOut
more air equals more fuel
only thing you have to do is lay off the pedal.
This
Old Dec 11, 2010 | 12:32 PM
amkaluta's Avatar
REALLY 16 and 20 thats not good!!! I was geting about 22 to 23 average before my plenum... I got 25mpg on a road trip before and that was crusing at 70mph to 75mph. NO way i can get that now.
Old Dec 11, 2010 | 05:16 PM
Tollboothwilley's Avatar
Winter gas sucks - normally drops 2-3 MPG just from the winter fuel mix ratios. Happens to me every winter. I go from 19-20 mpg around town and drop to 17-18.
The plenum spacer will not decrease your fuel consumption if you are driving conservatively.
Old Dec 11, 2010 | 05:31 PM
bulletproofpat's Avatar
I would say it's probably your driving style or you might be running a little rich. You should try resetting your ECU.
Old Dec 12, 2010 | 02:08 PM
amkaluta's Avatar
I thought after the plenum if anything you should be running lean?
How you reset it?
Old Dec 12, 2010 | 06:48 PM
grovefromnh's Avatar
Write down your radio presets. Disconnect your battery (neg terminal) for about 10 min. , Reconnect. Start car; reenter your presets, go for a quick drive. Enjoy!
Old Dec 13, 2010 | 07:58 PM
amkaluta's Avatar
Ill try it out.. Is there anything else it can be?
Daniel k.
Nov 3, 2015 09:52 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
