Put a iso thermal plenum spacer in now i get worse gas milage????
Old 12-10-2010, 04:17 AM
amkaluta's Avatar
Exclamation Put a iso thermal plenum spacer in now i get worse gas milage????
I recently put the iso thermal plenum on my Gand thought it supposed to get better gas milage but i get way worse and same driving type.. WHy is this anyone have or had this problem could it be something else?
Old 12-10-2010, 06:55 AM
grovefromnh's Avatar
Maybe you're using your newfound horsepower more than you think. I installed one a couple of weeks ago and my milage is the same.
Old 12-10-2010, 07:56 AM
PAIXAO's Avatar
Did you reset the ecu?
Old 12-10-2010, 12:28 PM
ratm68's Avatar
What is your driving style and how much MPG were you getting before? If you're able to average 20+mpg, then you're more likely to gain. But if you're averaging 16-18, then it will probably go down with more performance mod.
Just because you drive the same, doesn't mean any product will help or hurt performance. power = burning fuel.
Old 12-10-2010, 12:29 PM
gtoor1990's Avatar
Interesting...
Old 12-10-2010, 12:41 PM
0MGHI2U's Avatar
do a ecu reset.. i have the mrev2 and iso thermal spacers too
Old 12-10-2010, 12:51 PM
gtoor1990's Avatar
I have a 1/2" iso thermal spacer i had no problems... But could be because i did the tune right after doing all mods ( i have a cobb tuning access port )
Old 12-10-2010, 01:29 PM
dofu's Avatar
Get a tune. I'm willing to bet you're running rich after the install. Turning back the timing a notch or two might help too.
Old 12-10-2010, 01:54 PM
Ggirl35's Avatar
it could always be the winter fuel
Old 12-10-2010, 04:02 PM
amkaluta's Avatar
i use to get an average of 22 to 23 miles per gallon now its 19 to 20!!!
I did reset the ecu when i put it on or atleast i think i did it runs fine just the gas milage went down a good bit very noticable....
Old 12-10-2010, 04:21 PM
LightsOut's Avatar
SIETESG
more air equals more fuel
only thing you have to do is lay off the pedal.
Old 12-10-2010, 04:25 PM
Jeff92se's Avatar
Red Card Crew
Or there's a leak
Old 12-10-2010, 04:41 PM
Shakuya88's Avatar
Other mods?
Old 12-10-2010, 07:15 PM
amkaluta's Avatar
NO all stock besides the plenum and no resegnators on the exhaust..
How would there be a leak?
Old 12-10-2010, 10:35 PM
lovemyg88's Avatar
I installed mine a couple weeks and MPG is still the same. I also reset the ECU. I usually get around 16 MPG city driving and about 20 MPG on Freeway.
Quick Reply: Put a iso thermal plenum spacer in now i get worse gas milage????
