for exhaust installation
Old Jan 21, 2011 | 09:29 PM
jinc1026's Avatar
two jacks are enough to lift up the rear side of my car to install catback
exhaust system??
Old Jan 21, 2011 | 09:32 PM
Project's Avatar
Depends on how big you are. I would say yes, but be careful. Most exhausts come i three pieces that are seperated into a y pipe or h pipe, a straight pipe and then the muffller system itself. You can probably put the y pipe and straight pipe on then jack up the back or vise versa.
Old Jan 22, 2011 | 01:07 PM
freedonutss's Avatar
I hope you are using jack stands rather than "2 seperate jacks". Most exhaust systems come with the y pipe which would probably require you to have the front end in the air. Unless you are toothpick skinny
Old Jan 22, 2011 | 01:56 PM
Xet's Avatar
Xet
I did mine with only two jackstands, it is possible but you better be skinny and you better be ready to be very uncomfortable and squished. I would definitely recommend 4 if you want the job to be less painful and necessary if you are even really an average sized person.
Old Jan 22, 2011 | 02:10 PM
antodiaz's Avatar
Hopefully you don't have rusted bolts mine was a bitch to take off because of the rust. I used a ratchet with a breaker bar to take them off
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Spartan268
Aug 20, 2015 09:14 PM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
