Kinetix V+ Plenum....Worth it?
Old Jan 25, 2011 | 01:56 PM
SnglTrboG35's Avatar
I have my engine apart to do valve cove gaskets. Thinking of getting the Kinetix V+ Plenum. Is it worth it and should I get a spacer with it or instead of it?
Thanks
Old Jan 25, 2011 | 02:06 PM
jwrape's Avatar
I know the Kinetix is for the Rev Up
Old Jan 25, 2011 | 06:26 PM
Dsskyline's Avatar
Thanks
since you are turbo get a spacer to use with your stock plenum.
Old Jan 25, 2011 | 06:31 PM
Why do you think the spacer will be better than the plenum?
Old Jan 25, 2011 | 07:33 PM
Deemo's Avatar
im pretty sure that plenum provides good gains for f.i. so i would get that...not sure though, so don't quote me on that.
Old Jan 25, 2011 | 07:36 PM
350GT_Enthusias's Avatar
I have the Kinetix plenum on my G. I'm n/a for right now, and had a 1/2" spacer before i got the plenum. Even before a tune I noticed a difference between the spacer and the plenum. It flows quit nicely. I'd get it.
Old Jan 25, 2011 | 07:42 PM
SDGenius's Avatar
the V+ plenum is the composite one, shaped like the OEM w/a spacer built in. which is good for NA due to heat soak fighting characteristics but not good for FI because it can hold boost pressure. the kinetix plenum you want is the velocity manifold, replaced the SSV and is well suited for FI applications>>> http://www.kinetixracing.com/kinetix..._manifold.aspx
Old Jan 25, 2011 | 08:20 PM
So, the V+ will not handle the boost? Even 10psi or less? The SSV is a little out of my range for now. Either going to do V+ or spacer for now.
Old Jan 25, 2011 | 09:34 PM
SDGenius's Avatar
the V+ is made out of a composite material, the OEM aluminum upper plenum would be more ideal for boost.
Old Jan 26, 2011 | 12:06 PM
Dsskyline's Avatar
Come to think of it you should be good. I think the V+ is good up to 12-14 psi because it's stronger than the older ones the older ones would flex under vacuum and boost. I have the V+ now and love it just make sure not to over torque the bolts because it can crack. Post a vid after your install.
Old Mar 17, 2011 | 09:57 AM
350gt4dr's Avatar
can anyone answer me a question... will a motordyne 5/16" plenum spacer, and the kinetix V+ upper plenum, and the motordyne mrev2 manifold all fit under the hood?
Old Mar 17, 2011 | 10:29 AM
SDGenius's Avatar
^no point to run both
Old Mar 17, 2011 | 03:02 PM
350gt4dr's Avatar
so getting all 3 wont add any more hp than just the mrev2 and spacer?
Old Mar 18, 2011 | 07:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
No.
Old Mar 23, 2011 | 03:01 PM
FlyingMustache's Avatar
motordyne mrev and iso thermal spacer..
