2005 Sedan both Cats are bad
Old Feb 12, 2011 | 11:55 AM
Deadwrong's Avatar
I just found out that due to a ongoing misfire issue that both of my cats are bad and the dealer will want 3 grand to repair parts and labor included....Are there any aftermarket options or any I pretty much screwed at this point?
Old Feb 12, 2011 | 12:13 PM
chink-ah-saur's Avatar
Look up hfc.. And go somewere else to get it them installed
Old Feb 12, 2011 | 01:06 PM
DaveB's Avatar
First, get a second opinion. Both cats don't just die. There's no moving parts nor are they high tech. If they are both clogged (ie melted or covered in soot/fuel), then you've got some sort of engine trouble that's essentially causing an excessive lean or rich condition.
What mods do you have?
If both cats are bad, buy a used set. They're everywhere on this site and my350Z.com. You can pick up a used set for $100-200. Install should be around $150 or less.
Old Feb 14, 2011 | 07:34 PM
CLyons0203's Avatar
I just took my stock cats off yesterday. came off 05 sedan, worked fine when i took them off. I replaced them with a set of high flow cats (HFC) that i got. Let me know if you want them
Old Feb 15, 2011 | 07:09 PM
obender66's Avatar
I bet you didn't change kitty litter box on regular basis. Cats don't like that.
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
