Review of my modified lower plenum
Old May 5, 2011 | 12:23 AM
Hydrazine's Avatar
Originally Posted by juanmotime06
I'm about to try this myself on my 06 350Z 6MT. Im going to install the 03 lower plenum dyno then do the machining dyno again then do the plenum spacer then dyno again. I physicaly compared MD's plenum with a stock one and only found that they milled down and polished the front two runners. I didnt see any other milling or polishing. If everything goes well I plan on posting up a DIY with pictures within the next month.
There is definitely more to an MREV2 than that. Where did you get it from?
Old May 8, 2011 | 09:39 PM
LoSt180's Avatar
Here's what I've been up to. Pretty much just smoothed out the humps and inputs to the ports. Also shaved down the side of the runner in the back (#6?), it looked close to the top plenum wall, so I'm thinking it will help airflow a little around the side of that runner. Need to pick up a spacer and get this thing installed.
Old Jun 8, 2011 | 03:22 PM
VQdriver's Avatar
Good stuff. I've also searched out a couple 20pg threads about DIY plenum modifications, fake mrevs and this pretty much sums it up. My gut tells me even a plain non-revup plenum with a spacer works well in an otherwise stock revup motor.
Old Jun 8, 2011 | 08:48 PM
LoSt180's Avatar
I got a hold of a spacer and installed mine a few weeks ago. It definitely made a noticeable improvement. The butt dyno is happy
DIY nonrevup plenum on top, revup on bottom.
Old Jun 23, 2011 | 10:55 PM
LoSt180's Avatar
So I conned a co-worker, I mean a friend with a 350z asked me to take a crack at his manifold. After looking at it a little longer, I think the airflow around the 2 inputs that are closest to the outside edge could be improved. So I took this one a little bit further, in this picture it's the top left and bottom right portions I'm referring to:
I followed the flow of the casting a little better:
Here's the same area originally:
This is the other one I notched out:
Originally:
Original:
Thoughts? It's not installed yet, wondering if I should take the second area down a bit more.
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
EasySausage
Sep 24, 2015 01:06 PM
DRG35R
Sep 16, 2015 05:33 AM
vstring
Sep 11, 2015 02:50 PM
