o2 sensors connections different
Old Apr 24, 2011 | 12:26 AM
G35-31's Avatar
hi guys i have a 03 g35 with a 06 350z rev up motor in it, im using the old o2 sensors but the harness connectors are totally different from the old harness.... how could i fix this ?
Old Apr 24, 2011 | 01:19 AM
onthe3rdday's Avatar
Dude, I think 06 revup uses a wideband Upstream sensor that is incompatible. Someone correct me if I'm wrong. This should be easily correctable though
Old Apr 24, 2011 | 11:36 AM
Tollboothwilley's Avatar
you need to get the 2005 or 2006 wideband sensors. Car will run horribly since the narrowband use 0-1 V and the wideband use 0-2 V.
Connectors should be different - so that you don't try to use the 03-04 where the 05-06 should be used.
Also, there are differences in the rev-up ECU and extra sensors that require the REVUP wiring harness (hopefully you have that) and the ECU.
Old Apr 24, 2011 | 11:59 AM
G35-31's Avatar
Hey ***** Sup , yes I have the ecu and the harness the 2upper 02sensors are plugged in but I need the lower ones are Thoes regular 02 or wideband? And will Thoes 2 sensors really affect the car ?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
