COLD AIR INTAKE!!?? Opinions!!!!
Old Apr 30, 2011 | 12:53 AM
Cog_86's Avatar
Originally Posted by re-crue13
With all the searching I did, I found two options that work best wih the car.
1. The Stillen kit
2. Rev-Up box, K&N filter, Z-tube
I personally have #2 and love it. I removed the resonator under the box and plugged the hole in the box.
Any sound clips or video of the set up man?
Thanks
Old Apr 30, 2011 | 12:54 AM
Cog_86's Avatar
Originally Posted by G35 Dream
AMAZING!!!
Thank you!!
Old Apr 30, 2011 | 01:36 AM
thescreensavers's Avatar
Mr.202?
Originally Posted by DrewLe
This topic has been cover numerous times. You need to ask yourself "Am I the first person to put an intake on a G?" The answer is NO, so no need to make a thread on it.
^Read this thoroughly.
Performance wise, keep your stock airbox and get a Z-tube and K&N drop in filter.
And get a plenum spacer
Why K&N stock paper filter gets best performance and filters a ton better.
Old Apr 30, 2011 | 01:57 AM
Cog_86's Avatar
Thanks man!
Everyones saying to get the K&N filters. Hm
Old Apr 30, 2011 | 06:55 PM
NJ6MT's Avatar
The only thing wrong with the intake mod truth thread is that there is no dyno with a bone stock intake. A stock baseline would have been very helpful in that comparison.
Old Apr 30, 2011 | 07:09 PM
Mr.202?
^ Z tube is basically stock man lol
Old Apr 30, 2011 | 07:18 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Thanks
I haven't heard any with that exact setup, Im running a MD 5/16th spacer with a Z mid on my exhaust. I will record it to give you an idea.
Old Apr 30, 2011 | 07:54 PM
DrewLe's Avatar
Yep, essentially the same. The only difference is the OEM G-tube has baffles in it to reduce the sound of the intake. The Z-tube upgrade is to reduce the turbulence in airflow.
Old Apr 30, 2011 | 09:45 PM
NJ6MT's Avatar
Ahh. I am still a lowly g35 noob but I was under the impression that the z-tube K&N combo offered measurable power gains.
Old May 1, 2011 | 12:28 AM
Mr.202?
Thats what everyone thought but sexyrob did the tests and paper filter is better, I use paper anyhow since it filters a ton better.
Old May 1, 2011 | 10:08 AM
NJ6MT's Avatar
About how much power does the z-tube paper filter combo make over the stock setup?
Old May 1, 2011 | 02:56 PM
infamuz's Avatar
Old May 2, 2011 | 05:36 PM
Mr.202?
Minimal if anything, Z Tube and Paper filter is virtually stock.
Old May 2, 2011 | 09:28 PM
NJ6MT's Avatar
So the only reason somebody would install this combo is for more of a noticeable intake sound correct?
Old May 2, 2011 | 10:10 PM
  #30
Tunerz_Store's Avatar
r2c... they are redesigning the square plastic tube for an aluminum round tube. My car picked up 10whp over their original setup. Can't wait to get the round tube back, black nickel finish at that....
