DIY - Poor man's Z-tube
Old May 3, 2011 | 08:59 PM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by G35Papa
My friend commented on that as he runs his stock cover still Thanks Tim (it is Tim right? )
You got it and yes you got the name right as well!
It'll be nice to put names with faces in Sept.
Old May 3, 2011 | 09:52 PM
G35Papa's Avatar
Yes, that will be nice. I think this years meet is going to be bigger than the previous 2....maybe combined
Old May 4, 2011 | 12:23 PM
CLyons0203's Avatar
I would not recommend doing this at all. First a Z tube is cheap, I see them all the time on craiglist for $50-$75. Main reason I wouldn't do this is fear of sucking that cap over the hole into the engine. Look inside the factory airbox and you will se ALOT of ribbing and braces. Its there so the factory air box will not implode during WOT. The engine sucks alot of air, enough to cause flexing. If the cap isnt sealed down tight, it will suck into the engine...............then boom!
Old May 4, 2011 | 05:37 PM
G35Papa's Avatar
I didn't use a cap. I guess you are referring to the one DaveB did. The section I cut out goes over the hole completely and I used the thick plastic from the resonator. I can understand your warning but I just don't see it happening with how I did it.
Old May 4, 2011 | 05:44 PM
g35sweetness's Avatar
definitely agree with the above author, check out mine that i have listed for sale classified - you either break the gtube or take pieces of the gtube with it if you wanna break loose the bondo and the covering on the resonator hole...
Old May 5, 2011 | 01:25 AM
DaveB's Avatar
The reason I went with the cap was because I didn't want a shallow void where the lower resonator once was. The cap filled in the void. The cap I used was somewhat tapered plus I used marine-grade Goop sealant which is designed to live in much harsher environments than a 160 degree engine bay. I've used this stuff on other parts and previous modded intakes and I've never had it fail. It's too pliable and resilant. Plus, if in the off chance it were to fail, all the glue wouldn't fail all at once. I know there would be a problem because there would be one bad vacuum leak at a sealant break. In the one billion chance the cap where to actually make it into the pipe, past the throttle blade, and into the plenum, the farthest it could possibly go is an upper manifold runner. It get stuck there and I'd have to remove the upper manifold and pop out the cap.
With that said, Papa how do you like it? I love it. IMO, it's a deeper sound than the Z tube and I think the throttle response is better.
Old May 5, 2011 | 01:44 PM
G35Papa's Avatar
I'm actually running a Ztube I have a few aesthetic things going on under the hood and it just looks cleaner with the Ztube. My friend seems to be really enjoys it though
If you plan to keep the engine bay fairly stock and not start blinging it out, this is a great mod IMO. No need to spend the money ($50 bucks is $50 bucks ) on a Ztube to get the same (or less?) results.
Old May 5, 2011 | 06:54 PM
argue-won's Avatar
very creative mod. nice!
Old May 5, 2011 | 07:09 PM
Golden_Shower's Avatar
So were is the DIY for converting my Z tube to a G tube I wana go back to stock
Old May 6, 2011 | 11:32 AM
G35Papa's Avatar
LOL
Bring it over my house Mitch. Go for a cup of coffee, when you come back, it will be like magic! POOF back to stock!
Old May 6, 2011 | 11:38 AM
Could I drop of my car, get coffee and poof black housing headlights and a possible wire tuck, maybe even a painted Nismo .
Old May 6, 2011 | 11:49 AM
My Key's Avatar
If this happens for mitch, I too would like to experience it.
Old May 6, 2011 | 02:25 PM
G35Papa's Avatar
If you guys don't mind a spray paint overlay on your lenses and bumper, I think I can accomodate
Ok....back on topic. Make G tube go rawwwr
Old May 11, 2011 | 04:13 PM
LoSt180's Avatar
I did this to both my G and wife's FX intakes I had laying around in the garage. We both have the Stillen Z-tube. If this holds up and still sounds cool, I might have 1 or 2 z-tubes for sale.
Old May 11, 2011 | 04:24 PM
  #30
G35Papa's Avatar
Let us know how it turns out
