Passed Smog With Art Pipe Replicas
Old May 11, 2011 | 05:54 PM
g35sweetness's Avatar
This thing was only a 400 cell count ceramic catalytic converter that was welded onto my oem ypipe to pass smog. I was gonna have the second cat welded onto the midpipe as well but I didn't and still pass smog easily. The pollutants were all under 1.0 unit, and some were nearly 0.1 unit.
I had my Art Pipe replicas on and the thing spilled out white smoke but the cat pretty much cleaned it all up and no smoke at all. This is a nice trick for anybody who don't want to remove their test pipes or hfc to pass smog. Enjoy...
Attached Thumbnails Passed Smog With Art Pipe Replicas-ypipecat.jpg   Passed Smog With Art Pipe Replicas-ypipe-cat.jpg
Old May 11, 2011 | 06:06 PM
Silencer_0's Avatar
What the heck are ART pipe replicas?
Old May 11, 2011 | 06:12 PM
I posted pic and info last night but the mods shut it down because it was in poor taste on my part and forum rules... basically it was a "rip-off of Tony's ideas"... so I do not want to post too much info on this. In reverence to Tony and MD... thanx
Old May 11, 2011 | 06:16 PM
Silencer_0's Avatar
I see. Ok then.
Old May 11, 2011 | 06:42 PM
skidz88's Avatar
Well thats cool. Could you pm me more info on these replicas?
Old May 12, 2011 | 11:45 AM
DaveB's Avatar
I had my Art Pipe replicas on and the thing spilled out white smoke but the cat pretty much cleaned it all up and no smoke at all. This is a nice trick for anybody who don't want to remove their test pipes or hfc to pass smog. LMK if you guys have any questions...
Hmmm....that's a bit silly that your post got deleted because your test pipe setup emulated Motordyne's. I don't think that the MD product is patented yet and I guess I'd have a hard believing it could be formally patented since the resonance tuning technology utilized has already run it's patent course and has been used in all sorts on motor applications over the decades. I understand that MD wants to keep the ART pipes exclusive, but until the part is patented, how could this be considered a violation of site rules or the patent law for that matter?
Anyway, thanks for sharing your setup. I plan on doing something very similiar, eventually. I don't want to spend the $650 on the XYZ pipe and MD cat because I already have the sweet HR y-pipe and it makes the same gains as the XYZ pipe. Would that mean the XYZ pipe design emulated the HR Y-pipe's design since the HR pipe was first to market? All kidding aside, since the HR Y section joint much further downstream than the DE Y section joint, it will force me to put the cat in the midpipe, just on the other side of the flange that connects the Y-pipe and midpipe.
Do you notice a reduction noise with the cat?
What brand cat did you use? How much?
Any rasp or other strange sounds?
Old May 12, 2011 | 12:22 PM
Do you notice a reduction noise with the cat? - yes reduction by 1/3rd atleast
What brand cat did you use? How much? - i got the somethin"flow" from an exhaust store here for $95+tax
Any rasp or other strange sounds? - well i have a cheap exhaust system on my car so nothing will remove all of the rasp, not even with oem cats so this one i will leave alone since i can't answer it properly without more info on my part - sorry
I definitely agree with you on all that you have said above... Thank you!
Old May 12, 2011 | 04:00 PM
350z006's Avatar
That is not an ART pipe replica...it's an XYZ pipe replica, if you can even call it that...
Old May 12, 2011 | 04:09 PM
The 2 pictures refer to the oem ypipe modification - aftermarket cat added for passing smog...
The Art Pipe replicas are actually nonresonated test pipes modified with resonators/dead chambers branching out from the side of them... for more backpressure... thanx
Old May 13, 2011 | 12:15 AM
almost3flips's Avatar
Do you have a dyno chart of this?
Old May 15, 2011 | 11:08 AM
sexyrob's Avatar
as long as you don't sell your replica art pipes you shouldn't have an issue. there is nothing wrong with a little DIY ingenuity.
Old May 15, 2011 | 11:35 AM
DaveB's Avatar
https://g35driver.com/forums/tuner-d...pipe-dyno.html
Old May 15, 2011 | 01:18 PM
That's awesome! Kinda wish I stuck with my original plan of getting the hr y pipe over the xyz to save some monies....oh well.
This looks to be a great alternative for those who want to pass smog without buying the xyz with cat
Old May 15, 2011 | 01:33 PM
OCG35's Avatar
I dont get it... you welded a HFC so your test pipes would pass smog? I must be misunderstanding because that would be completely pointless.
Old May 15, 2011 | 01:38 PM
same concept as the xyz pipe with the catalytic converter piece
