hr y pipe and test pipe install
Old Aug 1, 2011 | 01:49 PM
yusoslo's Avatar
I am installing the M2 HR design y pipe this week along with resonated TP. I am wrapping the test pipes in header wrap to help eliminate any rasp. Will this bolt up with out any issue? I had a 350z before and installed a full exhaust, but I just saw a picture of a g35 install ,and the extensions look to be after the cats.
so do i need to order extensions, or will the test pipes bolt to the y pipe and fit to my stock catback?
Old Aug 1, 2011 | 02:03 PM
CandlestickPark's Avatar
ill Sedan
The TPs will bolt on to your Y-Pipe. An extension would only be needed for a Z midpipe to work on a G35.
Where have you read that wrapping the TPs in header wrap will eliminate any rasp? I've never heard that before and don't see how this is possible.
Old Aug 1, 2011 | 02:14 PM
yusoslo's Avatar
I came across it on youtube and other forums. I googled removing rasp from test pipes. There is a guy from Hawaii on youtube that have before and after vids.
<iframe width="425" height="349" src="http://www.youtube.com/embed/yXEjz46VA5o" frameborder="0" allowfullscreen></iframe>
I also believe the hr design helps eliminate any rasp as well
As to the header wrap, I believe it just dampens the vibrations or chance of rattle. If you see in his vids, there is a difference in tone of the cars exhaust.
Old Aug 1, 2011 | 02:16 PM
yusoslo's Avatar
no header wrap
<iframe width="425" height="349" src="http://www.youtube.com/embed/CUOyfl0heIs" frameborder="0" allowfullscreen></iframe>
Old Aug 1, 2011 | 02:20 PM
SDGenius's Avatar
still sounds raspy to me, no amount of wrap will cure rasp
Old Aug 1, 2011 | 02:24 PM
yusoslo's Avatar
true, his has the oem y pipe, and I am taking a gamble that the hr design and diameter will remove this sound. If I am wrong I will sell the tp and go with the ART pipe V2.
Old Aug 1, 2011 | 02:29 PM
SDGenius's Avatar
what mid-pipe/exhaust are you running? if it's less than 3" you'll only cause more rasp
Old Aug 1, 2011 | 03:23 PM
yusoslo's Avatar
Oem mid and rear
Old Aug 1, 2011 | 03:25 PM
SDGenius's Avatar
OEM has smaller ID than the M2 y-pipe OD, will add rasp.
Old Aug 1, 2011 | 03:53 PM
yusoslo's Avatar
I guess we will see. I will post vids.
Old Nov 23, 2011 | 01:57 PM
67Fastbackfan's Avatar
I'm installing some M2 test pipes next weekend. I have the Megan HR style y-pipe that I've already done some header wrap on to help prevent the rasp that I'm sure will be coming. I'll also be doubling up on the test pipes to help tone it down, but I'm almost sure I'll get some.
Old Dec 2, 2011 | 03:11 AM
Michael Joneser's Avatar
Do not double up on the header wrap, supposedly it can trap in moisture and promote corrosion. Also depending on where it is in the exhaust it might not let the metal expand enough and could be bad for welds. Some recommend painting even stainless with high temp paint before wrapping to prevent corrosion. There should be a recommended overlap by the manufacturer.
I doubt wrapping would do anything for wrasp but it might quiet down the twang heard in thinner aftermarket exhaust metals.
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Ray Feta
Aug 13, 2015 11:40 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
