Exhaust + Test Pipes Issues
Old Aug 8, 2011 | 11:05 PM
yusoslo's Avatar
Originally Posted by VEN0M
So far my Y pipe is stock. I want to avoid buy more crap at all costs. I dont want to be like "This will fix it" like i did with the Art pipes, and then be let down and have to lose out on that money.
Ryanm8, what did you do to fix it? Mine sounds like yours, but multiplied by 10.
I feel very confident you rasp is from this, as mine was. I would research a y pipe that has a HR design merger and the appropriate inlet and outlet you your art pipes and rear muffler section
Old Aug 8, 2011 | 11:48 PM
Zioxx's Avatar
Theres no point of him gettin a y-pipe unless his plannin on selling his HKS.
Buddy of mine had crawford hfc & hks exhaust and had rasp like a honda.
Switched to a X-pipe instead of his H-pipe solved his problem.
Im not sure if u read the post someone posted on here showing the low quality welds the inside of the H-pipe from the HKS exhaust has. Might be the problem.
Good Luck!
Old Aug 9, 2011 | 12:15 AM
VEN0M's Avatar
Good Luck!
That does make sense, but what about the Stillen exhaust? Im running that now with the test pipes, and thats what the video above was of.
Old Aug 9, 2011 | 12:33 AM
Zioxx's Avatar
If your exhaust combo is a combination of different inlets & outlets. That plays a big factor on the flow of the heat inside the exhaust. causing hissing & rattles.
If you run an oem HR/DE y-pipe with HFC or TPs your always going to get some sorth of noise. Since hfc/tps outlets are 2.5"-3" & the y-pipe inlet is 2"-2.25"
I might not be right but thats what I learned from my experiences.
Old Aug 9, 2011 | 12:41 AM
VEN0M's Avatar
Im definitely going to take this info down and see what i can find out to be best. Thank you very much for your help. In the mean time, if anyone else has any ideas
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
andresito7
Aug 1, 2015 04:53 AM
