350Z Tube Vs Stock
Old Aug 21, 2011 | 12:36 PM
keithk831's Avatar
350Z Tube Vs Stock
I installed my 350Z tube a couple days ago, and I have some questions. Has anyone noticed any proven gains from this tube, or is it mainly just for the sound? No doubt you can hear the intake a lot more when you get on it, and it sounds great...just wondering if it adds any power.
The stock intake tube actually looks pretty smooth inside. The holes for the resonators are small, and there are no obstructions.
Old Aug 21, 2011 | 01:03 PM
G35SedanGrn's Avatar
Mine added 15whp, but mine's a Z1 Ztube so when I added a Z1 sticker it added 30whp so now I can beat GTR's.
Old Aug 21, 2011 | 02:15 PM
keithk831's Avatar
Sweet! Maybe I'll have to pick up a 350Z badge for my grill for an extra 15hp...
Old Aug 21, 2011 | 03:06 PM
irishsig's Avatar
U can find pages of threads on this topic.
But to cut to the chase...the z-tube doesn't add any functional HP/TQ.
It's just one more piece that adds to the efficiency/performance of an engine.
It's benefits aren't realized until it's accompanied by other performance parts.
Old Aug 21, 2011 | 04:25 PM
keithk831's Avatar
That's what I thought. Thanks for the info!
I think i'll keep it on for now...I like the sound
Old Aug 26, 2011 | 06:26 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Rev-up box + K&N + z-tube + MD 5/16 ISO Spacer = Growl
Z-HR Y-Pipe + Z Mid-Pipe = Exotic OEM sound.
Power gains? A few ponies, only from MD Spacer.
Old Sep 12, 2011 | 07:44 AM
Trickstyle's Avatar
is the revup box and differnt than the non-revup? if so, is it still a direct swap?
Old Sep 12, 2011 | 09:27 AM
67Fastbackfan's Avatar
Just added my Z tube last week, along with K&N and MD Spacer. Sounds good and feels smooth.
Old Sep 12, 2011 | 03:11 PM
KingCobra's Avatar
The revup box has a bigger velocity stack (the metal piece that conducts the air into the filter, its taller) so it should help a bit...and it is a direct swap...
Or you can even get the zbox if you want, its much easier to change filters with that one, and if you find an 06+ box you would be very lucky since those are the revup boxes with bigger velocity stacks...
Old Sep 12, 2011 | 04:10 PM
.cakestar's Avatar
on a side note, i know there are some ppl that modified the g-tube and plugged off the resonator box at the bottom/ cut it off. what did you guys use to plug the hole?
Old Sep 12, 2011 | 05:35 PM
DaveB's Avatar
Salad dressing bottle cap and heavy duty marine-grade silicone Goop It's worked out fine for nearly 2 years.
Old Sep 12, 2011 | 10:29 PM
Trickstyle's Avatar
the lower air duct has a resonator in it? is the sound noticable when you remove it? is there another air filter down there too? wtf Nissan?... i know you have your reasons but man... K.I.S.S.
Old Sep 13, 2011 | 02:19 AM
keithk831's Avatar
There are two resonators...one on top and one that runs down.
Old Sep 13, 2011 | 04:44 AM
Trickstyle's Avatar
ima cover em up n see how much different it sounds...
i dont understand how a Z tube is better, it has less air inlets on the intake than the G tube does...
Old Sep 13, 2011 | 11:15 AM
keithk831's Avatar
I don't know where you got that from. It's basically the same tube, minus the resonators. It doesn't do anything for performance, just sound.
