throttle body install
Old Sep 6, 2011 | 11:46 AM
heythatsneat's Avatar
hey, i just bought a new throttlebody and i just want to make sure before i install it that after the install i do the idle reset and all those pedal combos?
i just dont want to get the tb on and find out that its messed up.. (on my hondas years ago the TBs were very sensitive and didnt like me changing them out..)
any response would be pretty sweet! thanks!
Old Sep 6, 2011 | 11:51 AM
Illuminati's Avatar
Pretty stright foward installation
Unbolt the Negative terminal to the battery
Take off your intake piping
Unplug the TB harness
Unbolt the 4 bolts around the TB
Inspect the gasket then reinstall
Old Sep 6, 2011 | 12:16 PM
herrschaft's Avatar
I believe the reset procedure is in the DIY section somewhere, but I always just disconnected the battery and reset everything that way. I have yet to do the actual reset procedures for anything and have had no issues.
Old Sep 6, 2011 | 01:03 PM
thanks guys!
yeah that pedal reset **** is real finicky.. first time it took me 30 minutes to get it right.
Old Sep 12, 2011 | 09:31 AM
67Fastbackfan's Avatar
It wasn't a swap, but when I had my 350Z, I took off the TB to clean it. Once I installed it everything ran fine. Didn't need the pedal reset, but then again, it wasn't a swap
Old May 22, 2012 | 12:38 AM
ThomasLee's Avatar
Bringing this back...
So just to clarify, you don't need to do the whole crazy pedal reset if you plan on installing a new throttle body?? Just leave the battery disconnected for a bit?
Hasanbaloch
Feb 29, 2024 08:45 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
03sedang35
Aug 29, 2015 07:56 PM
