Heat soak my azz
Old Oct 10, 2011 | 07:11 PM
obender66's Avatar
Originally Posted by obender66
I do not do drag racing-I do track with rpm range 4-6.5k. My main straight away max speed has dropped after I took Stillen intake out and put factory box in. I gotta try new things!
Dave, loss is 1% hp per 10 degrees change. 240 whp x 0.01 x 50/10=12 whp. Not 30 to 40. 12 hp loss is the worst case scenario for me-when I am driving home in 10 km/h traffic. I will say it again-I do not drag race.
As a stated in first post-this thread is not about benefits or not of intakes. I just think that heat soak issue is exaggerated.
Old Oct 11, 2011 | 12:02 AM
DaveB's Avatar
First off, you're willing to pay money to loose HP? Not to sound like a jerk, but you've posted nothing new here. Your finding were uncovered back as early as 2003.
Believe what you want to and it's your car, but let's not confuse other people into believing intakes do something for the these cars other than make noise and potentially loose power in warmer ambient temps. You titled this thread "Heat soak my azz" but the data you posted shows exactly what you're implying isn't happening. The aftermarket intake is most definitely heat soaking and also sucking in heated under hood air.
I datalog too. I can yank the Powerduct cover and over radiator snorkel from the OEM airbox and get 80% of the POP charger sound and all of the negative side effects.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
