Oh boy...stripped header bolt. Opinions?
Old Jan 3, 2012 | 01:44 PM
ryanm8's Avatar
So the nut on the stud that connects the header to my ART pipe is stripped. My buddy tried to weld another nut onto it, which we were going to try to use to get the other one off, but we were still unable to.
I ended up taking it to a shop and they're telling me that because of the other nut welded on to the stripped one that they can't do anything except replace the whole header (which is 3 hours of labor costs + the new header).
Does anyone know if there's anything I can do in this situation? The shop tells me there's nothing I can do to save the stud. I don't see how welding the nut on would affect anything. The weld is only on the outside, it's not touching the threads or anything. It's a weak weld at that, I think I could probably break it off if needed.
Would a sawzall work? I'm open to all ideas
EDIT: Sorry...thread title is wrong. It's the NUT on the stud is stripped, not bolt.
Old Jan 3, 2012 | 01:48 PM
redpearl99's Avatar
the bolt cant be saved, but you can get get a rusty/stripped bolt removing socket from sears or where ever you guys get your tools
the socket version of this is what im talking about
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old Jan 3, 2012 | 01:58 PM
redpearl99's Avatar
here, this is what im talking about
Old Jan 3, 2012 | 02:17 PM
ryanm8's Avatar
Oops...sorry. I meant the NUT on the header stud is stripped. Not bolt. So the stud can't be saved?
Old Jan 3, 2012 | 04:06 PM
JuicinJake's Avatar
that tool should work just fine then... you could get a dremel and grind the weld off, remove that nut and then use the listed tool to get the original stripped nut off. this is doable... just hope the weld didnt get into the threads.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
magnetism80
Jan 27, 2016 12:57 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
