Damaged Y Pipe, should I be worried?
Old Feb 9, 2012 | 01:24 PM
Trickstyle's Avatar
due to scraping since 2003, my Y pipe is pretty banged up... should I be concerned at all? I'm not lowered at all, stock all around suspension wise, but will I need a new Y pipe? I was told the HR Z y pipe is a great replacement, but I dont want to replace it right now if i dont have to.
Old Feb 9, 2012 | 01:37 PM
chink-ah-saur's Avatar
Looks fine to me
Old Feb 9, 2012 | 02:23 PM
Dsskyline's Avatar
any leaks in the damage areas? If not you should be good to go for now. The problem you may have later is rust forming in those areas
how did that happen going into a driveway or over a speed bump?
If you get another pipe the same thing will likely happen to that one if it's some where you go regularly.
Old Feb 9, 2012 | 02:38 PM
Trickstyle's Avatar
speed bumps on my old military base, there was a road that had this one HUGE speed bump. but since it was the only route out of the area, after a few weeks of constant complaints I got it extended so not nearly as much scraping going on now but I just saw that when I was doing my Big 3 upgrade and it worried be a bit.
Old Feb 9, 2012 | 11:10 PM
Massios's Avatar
You're fine until that corrugated tubing busts. The braided material is just a cover.
Danielek
May 1, 2022 01:28 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
