Magnaflow resonated x-pipe questions
Old Mar 10, 2012 | 05:17 PM
dreamreality's Avatar
Hi all, I just got an M2 (HKS rep) exhaust installed and looking to reduce the drone that I hear in cabin. Sounds great idle, but the freeway drone is annoying. I've been reading about the resonated x-pipe and quieting down the exhaust a little bit. Question is, I'm confused where the x-pipe goes/where it gets welded. Will a muffler shop know what to do with it? And any one with experience on how much drone it will reduce? Thanks. I'm new to this!
Old Mar 10, 2012 | 05:57 PM
Jairen's Avatar
They need to cut off the H-pipe and the resonators. Then weld the x-pipe in place of them.
As in my case, it greatly reduced the drone on the freeway. There is a little some noise, but definitely and improvement. Sometimes I can barely hear it.
Old Mar 11, 2012 | 07:58 PM
Thanks for the help. I'm just not use to the loudness yet, I guess.
Old Mar 12, 2012 | 11:06 AM
ratm68's Avatar
yup, replaces the H section and should line right up. I have it on my invidia g200 true dual. this helps even more with rest pipes or hfc. Even after burn in, that extra muffling chamber eliminates any of the annoyance factor from an exhaust.
Old Mar 15, 2012 | 11:43 AM
doeboy's Avatar
Replacing the crappy H-pipe like the others have stated with the Magnaflow resonated X-pipe will help out on droning and also help out giving some power back to the low end. I will give it a deeper growl as well!
Old Mar 16, 2012 | 02:52 PM
CaseyinGA's Avatar
M2 h pipe is 2.5" right?
Old Mar 17, 2012 | 12:33 AM
Yep 2.5".
Thanks for the help. I'm actually getting a new exhaust because the M2 didn't fit correctly on my coupe.
Old Jul 6, 2012 | 01:38 PM
thisiswang's Avatar
reviving this thread, cuttong out the H-pipe and resonators on the HKS replica is a big section of the exhaust. if the x-pipe mod is done.... will there need to be an extension welded on also? or is the 20 inches from the magnaflow x-pipe enough?
Old Jul 23, 2012 | 10:50 PM
str8upspeed's Avatar
Im wondering the same thing...i have the HKS hi flow and i keep reading about people getting rid of the H- pipe and replace it with the magnaflow x but i cant find pics on this. Sure would help alot if anyone has some.
Old Jul 23, 2012 | 10:57 PM
thisiswang's Avatar
Did a lot of research. Some people keep the "H" cross section and don't have to get extensions. But I recommend cutting the "H" out as its restrictive
Old Jul 24, 2012 | 02:17 AM
Jairen's Avatar
Definately cut the H-pipe section. Depending on what version you have, most will only have a 1/2-1" opening connecting the pipe making the H-pipe usless.
jsimonk
Dec 22, 2023 03:49 PM
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
nickmcc123
Aug 20, 2015 03:10 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
