Just got art pipe and tune....smoke during start
Old Mar 16, 2012 | 09:31 PM
jiggawuah's Avatar
I just got my art pipe and Osiris tune. Just noticed when I start from a dead stop that smoke is coming out of my exhaust tips. It's a good amount of smoke. Is that normal?
Old Mar 16, 2012 | 09:45 PM
PAIXAO's Avatar
I had test pipes (ART) for 500 miles on my car and it started consuming oil a quart every 400 miles. I experienced exactly what you described above before removing the pipes. Keep an eye on your oil level.
Old Mar 16, 2012 | 09:50 PM
jiggawuah's Avatar
Seriously ? Ah okay will do. My car is still under warranty so that's good but grr
Old Mar 16, 2012 | 09:57 PM
PAIXAO's Avatar
How many miles on your test pipes? Some burn off is to be expected during break in.
Old Mar 16, 2012 | 10:00 PM
VictoriousG's Avatar
Did you ask Fab, Titus?
Old Mar 16, 2012 | 10:01 PM
jiggawuah's Avatar
Not yet I'm at bjs right now lol but I bought them used. They're v1s and I didn't see the smoke until today? But it's a lot colder today
Old Mar 17, 2012 | 01:11 AM
Silencer_0's Avatar
Didn't you say you had oil in your valve covers? Oil consumption perhaps.
Old Mar 17, 2012 | 01:38 AM
Javi04's Avatar
It will smoke for the first 1000 miles. When I first put mine on it smoked more because my engine was consuming oil. Had my engine replaced and just put them back on 2 weeks ago, no smoke and no oil consumption. (crosses fingers)
Edit
Just saw you got them used, how many miles on them?
Old Mar 17, 2012 | 02:56 AM
jiggawuah's Avatar
Yeah I got the valve covers replaced already and lame my engine is not even a rev up but ima check my oil level and see tomorrow...
And Idunnos how many miles were on the pipes but since theyre v1s I'm guessing more than a couple thousand miles...
Old Mar 17, 2012 | 03:13 PM
jiggawuah's Avatar
quick update. checked my oil and it was at the bottom last notch of the stick... my car is still under warranty what should i take off to bring it to the dealership to get it tested for OC? I have art pipes. fujitsubo from the Y pipe back. Stillen intake/z tube and motordyne spacer. Should I take them all off before bringing it in? thanks for the help guys
Old Mar 17, 2012 | 03:32 PM
herrschaft's Avatar
^I would have it tested. I would also convert everything back to stock just to be safe.
Old Mar 17, 2012 | 05:53 PM
jiggawuah's Avatar
ughhhhhh i think its time to sell my car.. but parting out is so annoying and i JUST got my osiris tune
Old Mar 18, 2012 | 12:18 AM
CPJ LB's Avatar
just curious...how long were you running your mods prior to getting the Uprev tune?? possible engine issues prior to getting the tune -- air/fuel mix was prolly lean...
...hope the issue is something minor. G/L with everything....
Old Mar 18, 2012 | 01:00 AM
jiggawuah's Avatar
hmm.. the spacer since the car had like 5000 miles and z tube/intake around the same time from original owner. exhaust components at 50k? and tune and art at 72k. and its been running lean since exhaust..so at least for more than 20k its been running lean. i'm pretty sure it was consuming oil before but art pipes and correct afr made it 10x worse..
Old Mar 18, 2012 | 02:41 PM
jiggawuah's Avatar
So I put in 2 qts yesterday and thought it was enough. Didn't drive the car at all yesterday. Started it up this morning an it was still smoking like crazy went to check the oil and it was pitch black and still didn't look like it had enough. Went and bought and extra qrt of oil and now its stopped smoking....
2 questions:
It smokes like crazy since the engine is dying for oil?
And would oil consumption turn my oil pitch black? Cause it's been super black the last 3 oil changes all changed before 5k intervals
