Need your help
Old Aug 2, 2012 | 07:29 PM
tt_sedan's Avatar
Need your help
hi guys i'm planing to put rev up intake manifold we 5/16 plenum spacer in my non rev up engine any problem with that
Old Aug 2, 2012 | 08:41 PM
Algy's Avatar
There shouldnt be a problem.
Old Aug 2, 2012 | 09:10 PM
tt_sedan's Avatar
Thanks for the reply but the car gain more power with that
Old Aug 2, 2012 | 10:23 PM
Algy's Avatar
Its kind of hard to understand you.
we = with?
replay = reply?
Yes, the car should gain a good amount of power say 9-12hp gain.
Old Aug 4, 2012 | 05:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
You won't gain any extra power from the rev-up lower manifold but the spacer will provide good bang for the buck. HTH
Old Aug 4, 2012 | 07:54 AM
tt_sedan's Avatar
but the rev up lower plenum is not supposed to be the same as the mrev2 ??
Old Aug 4, 2012 | 11:58 AM
GT3050's Avatar
The rev up plenum us not the same as the MREV2. I would just keep your stock lower plenum and add the spacer.
Old Aug 4, 2012 | 12:26 PM
herrschaft's Avatar
No, its the non-revup lower intake plenum that the MREV2 was based off of. The upper manifolds should be the same. All you need for your car is the spacer.
Old Aug 5, 2012 | 03:36 PM
tt_sedan's Avatar
thanks for the reply guys i know the mrev2 is base on non rev up lower plenum with some porting works but i thought that was for have the same efficiency that the rev up lower plenum has correct me if i am wrong
Old Aug 5, 2012 | 03:55 PM
herrschaft's Avatar
^You have it backwards. The rev-up plenum has the worst efficiency, which is why those with the rev-ups need both the spacer and the MREV2.
