Berks HFC + hr pipe?
Old Dec 15, 2012 | 11:03 PM
dj714's Avatar
Question Berks HFC + hr pipe?
Anybody have this set up with stock exhaust.
Anybody have any sound clips?
Any issued with this set up?
Old Dec 15, 2012 | 11:12 PM
bluedevils95's Avatar
All i can find is the HFC only. Still looking around
Old Dec 15, 2012 | 11:26 PM
dj714's Avatar
Ya same problem I've had
Old Dec 15, 2012 | 11:31 PM
gary c's Avatar
Had you done a SEARCH you would have found BERK'S HFCs aren't the best option. F1 is better and what I went with after my BERK'S failed. Adding HFCs to a OE exhaust will cause major rasp, factory exhaust isn't designed for that kinda volume! Save your $$ and in 6 months buy a quality exhaust with HFCs, you'll be glad you did....Gary
Old Dec 15, 2012 | 11:34 PM
dj714's Avatar
Got the berks for $75 so I couldn't pass them up specially because at works if the inner fail I can still use them as test pipes. I'm hopping the addition of the 07 hr pipe would help a bit with the rasp.
Old Dec 17, 2012 | 12:49 AM
SAMzG35's Avatar
G35
I read that HFCs on stock exhaust will cause major rasp but after I installed it its nowhere near as bad. Matter of fact barely there.
However a decent aftermarket exhaust is the way to go nonetheless
Old Dec 17, 2012 | 12:57 AM
dj714's Avatar
Ya really wonder how it sounds with the hr y pipe
Old Dec 17, 2012 | 01:05 AM
SAMzG35's Avatar
G35
I do have Megan racing y pipe HR style as well installed. With that combo it's a bit louder. Nothing too crazy
Old Dec 17, 2012 | 01:06 AM
dj714's Avatar
Sound clip?
Old Dec 17, 2012 | 01:08 AM
SAMzG35's Avatar
G35
Never took any. But I can probably take one tomorrow.
It's pretty much stock tone. Just a touch louder. Doubt noticeable in a video
Old Dec 17, 2012 | 01:10 AM
dj714's Avatar
Sweet thanks
Old Dec 17, 2012 | 01:24 AM
SAMzG35's Avatar
G35
Listen to nismo exhaust. Pretty sure you'll like it
Old Dec 23, 2012 | 07:49 PM
cthrulies's Avatar
Listen to the advice of knowledgable forum members
Berk HFC's + hr y-pipe on an OEM coupe exhaust will either rasp, hiss or rattle. I had that setup and even adding resonators did not provide an acceptable exhaust note and it drove me crazy. Also the exhaust shop tech did not want to deal with the nonstop modifications.
Do it right the first time. I would recommend Motordyne Art Pipes + Motordyne full exhaust. However, a cheaper alternative would include Berk HFC + Magnaflow 11386 + HKS replica.
BTW, you will need a tune otherwise save your time and money. Do not try to reinvent the wheel, my opinion.
Old Dec 23, 2012 | 08:00 PM
dj714's Avatar
But it should sound better then just berks by them self over berk + hr y pipe
Old Dec 23, 2012 | 08:51 PM
SAMzG35's Avatar
G35
Sorry but i don't agree with cthrulies. I have FI HFCs and Megan y hr style and sound no different than stock. Maybe louder in my ears but nothing obvious.
The HFCs with magnaflow might be okay. However most if not all hks replicas sounds like a$$
