Rev up air box or stillen high flow air box?
Old Dec 30, 2012 | 10:38 PM
jonavalos93's Avatar
Just installed my 5/16 copper plenum spacer and installed a Z-tube. Didn't get the sound I expected from the z-tube using my stock air box and filter. I was planning on getting the Rev up air box with the k&n drop in due to the larger opening design of the rev up. But will I get any difference with this set up or would I have to go With the stillen and cone shaped filter? Isn't the cone shaped filter essentially a pop charger? Lmk guys what you think?
Btw I have an 05 5AT Gcoupe
Old Dec 31, 2012 | 12:05 AM
gary c's Avatar
Check it out on www.stillen.com, his CAI is made of plastic composite and comes with a giant K&N filter and it's own air box. You won't have issues with heat soak due to the construction. Do you understand what heat soak is and how it effects RWHP in warm weather? I keep a Stillen Z-Tube/CAI (comes with CARB sticker) as a backup just in case our state gets more chicken **** with it's smog checks. They've dropped the sniffer tests, only time will tell what they'll be looking for now but I'm off the hook this year....Gary
Old Dec 31, 2012 | 12:20 AM
Lol ya I get the heat soak and such, at this point I was looking for more of a growl. Would I get a better growl from upgrading my non rev up air box to the rev up air box with k&n or rather with the stillen? Does the shape of the filter cause the sound?
Old Dec 31, 2012 | 01:17 AM
dukehotty's Avatar
I have tried different intakes including rev and non rev with and wo KN filter. The best sound I got was from the OEM Z tube and Wolf Pop Charger. When I put on my new exhaust it was TOO loud so I went to z tube, rev box and KN.
Old Dec 31, 2012 | 01:58 AM
You know what I think you just helped me make up my mind lol. I'm going to just do rev up with the k&n I already installed my oem z tube. Thank you guys!
Old Dec 31, 2012 | 03:03 AM
dukehotty's Avatar
Used Wolf pop chargers show up here used. They are pretty inexpensive and might be worth a shot just so you can hear it. If the sound is what is important to you.
Old Jan 3, 2013 | 02:43 AM
laxdude362's Avatar
I just installed a stillen z tube. I am waiting on my R2C Cone Filter and Stillen Air Box.
Old Jan 3, 2013 | 03:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
Are you sure the Stillen box is big enough for the R2C? I have the R2C intake and the filter's huge.
Old Jan 3, 2013 | 03:42 AM
laxdude362's Avatar
When I ordered the filter, I had option to select which air box I had. Stillen was one of the choices. I'm assuming that was to ensure proper fitment of the filter. Bought it from Z1 Motorsports.
Old Jan 18, 2013 | 12:16 AM
GT3050's Avatar
If you want sound I would def go for the stillen... I have the rev up box with a z-tube/k&n as well as a 5/16 spacer and MREV2 and it's only slightly louder than stock.
Old Jan 18, 2013 | 11:53 PM
laxdude362's Avatar
Well received my Stillen air box today, finally. The company I ordered the R2C filter from appears to have sent me the wrong one because it doesn't come even close to fitting. So I'm in the process of getting a smaller one.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
